Possible to require specific products in order to be able to checkout?
9 years 2 months ago - 9 years 2 months ago #275318
by jazzmang
-- Joomla version -- : 3.7.4
-- PHP version -- : 5.6.31
Got a odd request to require a minimum of 4 specific, different products in any given order.
I see I can set a minimum of just 4 products (of any kind) per order via shipping methods.
But I see no way to require specific products in an order.
Is there a way that I'm missing or would this require a custom plugin or changes to a particular view?
Last edit: 9 years 2 months ago by jazzmang.
9 years 2 months ago #275319
by Jerome
Replied by Jerome on topic Possible to require specific products in order to be able to checkout?
Due to the specificity of the "restriction", it would require a custom plugin.
Best would be to use "onBeforeOrderCreate" trigger ; check the cart content and authorize or not the rest of the workflow thanks to the " $do " variable in the trigger.
www.hikashop.com/support/documentation/6...#onBeforeOrderCreate
Time to create page: 0.146 seconds
