remove products from cart when checking out programmatically
8 years 3 months ago #294064 by twscott
hi,
In our shop, when user buy more than $500, he could choose a free gift into cart.
While in checking out, user remove the products from cart we need to check if the gift need to be removed,
Could you tell me which program and how to achieve that?
8 years 3 months ago #294065 by nicolas
You have these triggers which are called each time a product is added or removed from the cart:
onAfterProductCheckQuantities(&$products, &$cart, $options)
onBeforeCartSave( &$cart, &$do)
onAfterCartSave( &$cart)
so you can implement a trigger in a plugin of the group "hikashop" and do the code you want there.
Beware of the fact that if you update the cart with the functions of class.cart while you are in these triggers, you might risk creating a loop which will crash the processing of the page.
The following user(s) said Thank You: twscott
8 years 3 months ago #294203 by twscott
Thanks, Nicolas, It works.
But there is a new issue that, the product is removed from the cart in database, but in the front end, the product is still there.
How can I refresh cart in the front end?
Thanks again
8 years 3 months ago #294210 by nicolas
You'll need to clear the cache of the cart in class.cart and in the checkoutHelper after you change the cart data in the database. I think something like that should help :
hikashop_get('helper.checkout'); $checkoutHelper = hikashopCheckoutHelper::get(); $cartClass = hikashop_get('class.cart'); $cachedCart = $checkoutHelper->getCart(); $cartClass->get('reset_cache',$cachedCart->cart_id); $checkoutHelper->getCart(true);
Time to create page: 0.177 seconds
