Problems with address entry and change - popup
8 years 3 months ago - 8 years 3 months ago #296234 by wdburgdorf
-- Joomla version -- : 3.8.10
-- PHP version -- : 7.1.1
-- Browser(s) name and version -- : doesn't matter
-- Error-message(debug-mod must be tuned on) -- : no error message
On the checkout page, there is a list of customer addresses. New addresses can be added, existing ones can be changed. When clicking on a pencil to change an address, a new page opens with an entry form. This page is unstyled, it should probably appear as a popup.
When clicking "New address", there is actually a popup with a form. But after finishing and clicking OK, the popup does not close. Instead, it continues to another page within the popup, and then the whole site can be browsed inside the popup.
If the popup is closed after adding an address, it just closes, the cart page is not updated, so the new address does not show up until the page is reloaded - confusing.
Screenshot of form popup: cl.ly/tQ1K
EDIT: To make sure it is not just our template, I switched to Protostar - same results.
EDIT2: Failing popup on address change was my mistake - fixed. Problems with bad popup content and non-updating cart page remain.
Last edit: 8 years 3 months ago by wdburgdorf. Reason: Added info
8 years 3 months ago - 8 years 3 months ago #296246 by Philip
Can you provide an Url link in order to process some tests ? Provide as well a step by step process to reproduce your issue.
I suspect a Javascript error...
Awaiting news from you.
Last edit: 8 years 3 months ago by Philip.
8 years 3 months ago #296330 by wdburgdorf
Thanks for your reply.
How can I send you a private message for a logn? Otherwise you could just create an account as a client in the cart.
The process is then:
1. add product to cart
2. go to cart
3. register
4. log in
5. add or change address (URL: www.sternphila.ch/kasse/kasse/task-step/step-1 )
Regards, Ralf
8 years 3 months ago #296334 by nicolas
Turn off the "checkout legacy" setting of the HikaShop configuration in order to use the new checkout system and it will work fine as it doesn't use a popup anymore. Also, the checkout is better with the new system.
Also, with the old checkout, you have the "Address selector" setting you can use to not have a popup and use instead a form. It will reduce a lot the problems with popups due to third party systems.
8 years 3 months ago #296377 by wdburgdorf
Thank you, that helped. I had to redo some of the styling, but it's ok now.
Just one issue: Error messages now appear twice: cl.ly/0v40340C1L1p
Would you have a fix for that?
Thanks!
8 years 3 months ago #296389 by nicolas
Thank you for that feedback. We didn't know about that problem.
I've added a patch for it.
Download again the install package on our website and install it on yours and you'll get the patch for that.
8 years 3 months ago #296541 by wdburgdorf
Thanks, works, great!
