- Thank you received: 1
Cart module didn't refresh after putting a product in
- Marsipulami
- Joomla 3.0 Newbie :)
8 years 3 months ago - 8 years 3 months ago #296607
by Marsipulami
You have to be patient with me
Cart module didn't refresh after putting a product in was created by Marsipulami
-- Joomla version -- : 3.8.11
-- PHP version -- : 7.0.2
-- Error-message(debug-mod must be tuned on) -- : Cart didn't refresh after putting a product in
HI Guys
I have a problem but didn't know, if it never worked or since the update
When i put a product in the cart, it didn't refresh it self. The cart module didn't show any prodcts.
When i refresh the side manually, then it shows the product in the cart module.
Can i make a refresh anywhere in the hikashop settings?
I have the mini cart as module in the sidebar.
Same Problem with IE and Chrome.....
Best wishes
Marsipulami
HI Guys
Best wishes
Marsipulami
Last edit: 8 years 3 months ago by Marsipulami.
- Marsipulami
8 years 3 months ago - 8 years 3 months ago #296609
by Marsipulami
Replied by Marsipulami on topic Cart module didn't refresh after putting a product in
Ok afterdisabling the add to cart legacy in the settingsit works...
But there must be a problem in the legacy settings now right?
Best wishes
Marsipulami
Best wishes
Marsipulami
8 years 3 months ago #296612
Replied by nicolas on topic Cart module didn't refresh after putting a product in
It's something linked to the update yes. You've updated the cart module but still using the old add to cart buttons.
Turning off the add to cart legacy setting is a good thing to solve that issue.
In fact, you should even turn off the other legacy settings. They are only useful to keep on if you have issues when turning them on. In fact, when you install a new HikaShop, they are automatically off since you normally want to use the new systems.
- Marsipulami
8 years 3 months ago #296786
by Marsipulami
Thanks Nicolas
So i will turn all legacy settings of.
Best wishes
Marsi
Best wishes
Marsi
