Possible to fix a product in the cart?
7 years 7 months ago #305048 by Polenmarkt
is it possible...or does it give a way to fix a product in the cart?
So, that the customer makes his order and get this product also.
If he dont want this product then he must cancel it.
has anybody an idea?
regards, Krystoff
7 years 7 months ago - 7 years 7 months ago #305066 by Philip
Before answer you, we will need more elements to better understand context.
In this idea, can you :
- Detailed what do you mean by "fix" the product in the cart ?
- Does this operation must be done by the customer or the shop owner ?
About the other part of your message :
"If he dont want this product then he must cancel it."
=> It's possible to allow customer to remove a product from his cart by using, see my screenshot
Awaiting news from you to move forward on your subject
Last edit: 7 years 7 months ago by Philip.
