- Thank you received: 2
Display Product Weight in original format/unit
6 years 7 months ago #317074
by jtquinto
Display Product Weight in original format/unit was created by jtquinto
-- HikaShop version -- : Business 4.2.2
I'm trying to display the product weight in the Shopping Cart (and Checkout Cart), but when I access $product->product_weight and $product->product_weight_unit, it shows them in the general cart weight.
For example: a 50g product and a 1Kg product show "0.05kg" and "1,000kg", respectively. I'd like to be able show them as "50g" and "1Kg" on the product line-items.
How can I show the product weight in their original unit/values? (items have "50g" and "1kg" as their actual weight entries)
6 years 7 months ago #317079
Replied by nicolas on topic Display Product Weight in original format/unit
In the variable $product of the view file used to display this area, the weight and unit are converted during the loading of the cart so that the total weight of the cart can be calculated for shipping methods.
So to get the original weight and unit, you should find them in the attributes $product->product_weight_orig and $product->product_weight_unit_orig or you can even reload the product data from the hikashop_product table with a MySQL query if necessary.
6 years 7 months ago #317323
by jtquinto
Replied by jtquinto on topic Display Product Weight in original format/unit
6 years 7 months ago #317328
And you confirm that this product has 500g configured in its settings ? Not 0.5kg ?
Then just reload the data from the database like that:
$class = hikashop_get('class.product');
$data = $class->get($product->product_id);
echo $data->product_weight.' '.$data->product_weight_unit;
6 years 7 months ago #317352
by jtquinto
Great! That did it.
Thanks, Nicolas!
Thanks, Nicolas!
