AGB checkbox problem
5 years 9 months ago #328874 by Nicole Lewin
Hello all,
I have the following problem.
If I want to accept the terms and conditions just before completing the order, the hook is removed again immediately. It is therefore not possible for me to accept the terms and conditions to complete the purchase process.
What can I do here?
It must be related to the last update to version 4.4.0.
For your information I use Hikashop Essential.
Does anyone know a solution? Thanks in advance.
Many greetings
Nicole
Translated with www.DeepL.com/Translator (free version)
5 years 9 months ago #328878 by nicolas
Replied by nicolas on topic AGB checkbox problem
It probably comes from an old view override.
Check if your have the file templates/YOUR_TEMPLATE/html/com_hikashop/checkout/show_block_terms.php via FTP.
If you do, rename the file and it will deactivate the override.
If you don't, please provide a link to the shop so that we can check on the situation there.
The following user(s) said Thank You: Nicole Lewin
5 years 9 months ago #328918 by Nicole Lewin
Replied by Nicole Lewin on topic AGB checkbox problem
Hello Nicolas,
it work's! Thank you very much!
