Refreh does not work on mini cart
5 years 8 months ago - 5 years 8 months ago #330163
by lacasetta
my site with Hikashop
www.lacasettabio.it
Refreh does not work on mini cart was created by lacasetta
Hi, I noticed that on my minicart does not work the refresh/update button.
The refresh/update works fine on the check-out cart.
Could you help me, please?
Thanks a lot
Best regards
Thanks a lot
Best regards
www.lacasettabio.it
Last edit: 5 years 8 months ago by lacasetta.
5 years 8 months ago #330170
Replied by nicolas on topic Refreh does not work on mini cart
The refresh actually works there if you enter the new value in the input field and click on the refresh button.
From what I can see, it only doesn't work when you use the - and + buttons to change the quantity before pressing it.
And if I check the console of my browser when I do so, I can see some javascript error when using the refresh button.
And I can also see that the javascript of this button has been customized (which is why you get that error) :
i.imgur.com/UlUfyi9.png
Apparently, that cart module is customized by your template or something else.
I suppose that if you rename the file templates/YOUR_TEMPLATE/html/com_hikashop/product/cart.php via FTP, it will then work fine, which will confirm that the issue comes from some customization in that view file override.
5 years 8 months ago #330225
by lacasetta
www.lacasettabio.it
Replied by lacasetta on topic Refreh does not work on mini cart
thanks for your help.
In templates/MY_TEMPLATE/html I have any com_hikashop folder.
Also I checked into hikashop > display > views and set my frontend template
and there is any customization.
Could you help me to find where could be the customization you said?
Thans a lot
Best regards
Thans a lot
Best regards
www.lacasettabio.it
5 years 8 months ago #330257
Sorry, I tried to look into the issue today but I'm not able to access your frontend. I'm getting this error:
i.imgur.com/yLDd9l6.png
It seems to come from your template trying to load bootstrap.
5 years 8 months ago #330258
by lacasetta
www.lacasettabio.it
I see this issue and I thought that you were working.
I saw that you started to work this morning and then, in the late morning, I saw the issue.
I haven't touched anything.
But it doesn't matter, at this point I'll restore the site from yesterday's backup.
I'm going to give you notice as soon as done
Best regards
Best regards
www.lacasettabio.it
5 years 8 months ago #330263
by lacasetta
www.lacasettabio.it
OK, the site is working again
www.lacasettabio.it
5 years 8 months ago #330334
Replace the code:
by:
in the file components/com_hikashop/views/layouts/tmpl/quantity.php and it should fix the problem.
Replace the code:
<a class="hikashop_no_print" href="#" onclick="<?php echo $script; ?>" title="<?php echo JText::_('HIKA_REFRESH'); ?>">
<a class="hikashop_no_print" href="#" onclick="var input = document.getElementbyId('<?php echo $id; ?>'); if(input.form.onsubmit && !input.form.onsubmit()) return; input.form.submit();" title="<?php echo JText::_('HIKA_REFRESH'); ?>">
5 years 7 months ago - 5 years 7 months ago #330410
by lacasetta
www.lacasettabio.it
I'm sorry but there is the same issue always.
In error console browser now I have:
Uncaught TypeError: document.getElementbyId is not a function
onclick
onclick
www.lacasettabio.it
Last edit: 5 years 7 months ago by lacasetta.
5 years 7 months ago #330453
Sorry, there was a typo in my previous message. The text getElementbyId should be getElementById
Please change that and it should be better.
5 years 7 months ago #330460
by lacasetta
www.lacasettabio.it
yes, now it works fine!
Many thanks
Best regards
Many thanks
Best regards
www.lacasettabio.it
