- Thank you received: 11
Custom fields remarks retained at checkout flow
- ler@singmuiheng.com
4 years 11 months ago #336516
by ler@singmuiheng.com
-- Joomla version -- : 3.9.21
-- PHP version -- : 7.3.31
The custom fields for remark will retain when doing the second checkout. Can you please help to check on this issue?
youtu.be/yCGgFeC6nEs
4 years 11 months ago - 4 years 11 months ago #336518
by Philip
Replied by Philip on topic Custom fields remarks retained at checkout flow
Can you provide these elements in order to allow us to progress on your subject :
- Url link to your website
- A detailed step by step process in order to reproduce your issue.
- Provide your relative custom field screenshot
Awaiting your elements to progress on your issue.
Last edit: 4 years 11 months ago by Philip.
4 years 11 months ago #336575
Replied by ler@singmuiheng.com on topic Custom fields remarks retained at checkout flow
Here is the url
1) Go to add any item to the cart
2) And proceed to checkout, write some remark at the remark section and make payment using online banking
3) Cancel the online banking transaction and let the order fail to make payment
4) And add any item to the cart again and proceed to checkout, you are able to see the remark that you have written in step 2 show out.
4 years 11 months ago - 4 years 11 months ago #336588
by Philip
As you will surely see I have done a lot of tests, with different browsers, and I think this is where is the problem.
In details, with some navigator like Chrome I'm not able to reproduce your issue, with other sometimes we are able to reproduce like Edge.
The issue is quite for sure on the navigator side and his configuration, we invite you to proceed like us with several navigator to see it by yourself.
This means that you haven't the solution, each navigator and his configuration will allow or not this issue to emerge.
Time to create page: 0.183 seconds
