Die Adresseingabefelder werden beim auschecken nicht angezeigt,
4 years 11 months ago #337413 by michael_1969
-- HikaShop version -- : 4.4.4
-- Joomla version -- : 3.10.3
-- PHP version -- : 4.7
Hallo,
wenn meine Seite online ist werden die Adressfelder beim auschecken nicht angezeigt, nur dann wenn die Seite Offline ist.
Die Abfrage funktioniert soweit das die Fehlermeldung erscheint, bitte rechnungsadresse und versandandresse angeben, nur die Felder um die anzugeben erscheinen nicht.
Vielen Dank schon mal,
VG Michael
4 years 11 months ago #337419 by nicolas
Could you provide the URL of the shop so that we can reproduce the issue in order to analyze the situation ?
4 years 11 months ago #337422 by michael_1969
4 years 11 months ago #337425 by nicolas
The "address" view of the "checkout workflow" can only display the address interface after the user is logged in, or has filled the "guest form".
However, you apparently removed the "login" view from your checkout workflow and thus this is not possible anymore.
Please add it back.
And if you don't want the registration, just set the "registration" setting to "guest" under the "Checkout" tab of the HikaShop configuration.
That way, the customer will just have to enter his email address and address during your checkout.
The following user(s) said Thank You: michael_1969
4 years 11 months ago #337435 by michael_1969
it works, thank you.
Greets Michael
