- Thank you received: 1
Cart module not displaying for certain menu items
4 years 10 months ago - 4 years 10 months ago #338179
by aftertaf
Cart module not displaying for certain menu items was created by aftertaf
socouture-rouen.fr/
-- Joomla version -- : 4.0.5
-- PHP version -- : 8.0.13
Thanks for such a great and easy to use shop..
That said, i have a small issue : The cart module is set to be visible on All Pages (i've double-checked)...
It is visible on every page & menu link except 2 menu items: both are Category views.
I've inspected the page and the DIV isn't even loaded & hidden, its just not there...
Any help would be appreciated.
- index.php?option=com_hikashop&view=category&layout=listing
Last edit: 4 years 10 months ago by aftertaf. Reason: solved
4 years 10 months ago - 4 years 10 months ago #338181
Replied by nicolas on topic Cart module not displaying for certain menu items
Thanks !
HikaShop modules have specific display settings that you can activate/deactivate to display or not the module based on the type of the page.
For the cart module, it's under the "HikaShop options" tab:
i.imgur.com/aShj0IX.png
That allows you to display or not the module for different type pages under the same menu item.
So I suppose that you must have turned off some of these display settings for that cart module.
Thanks !
Last edit: 4 years 10 months ago by nicolas.
The following user(s) said Thank You: aftertaf
4 years 10 months ago #338185
by aftertaf
Replied by aftertaf on topic Cart module not displaying for certain menu items
duh!!!
i didnt find those settings
thanks, i thought i was going mad!
merci bcp ! ! !
merci bcp ! ! !
