Add to cart not going to checkout after updating Hikashop
2 years 4 weeks ago #363981 by nijale
-- HikaShop version -- : 5.1.1
-- Joomla version -- : 4.3.4
-- PHP version -- : 8.1.29
I just updated Hikashop to 5.1.1. I have the cart notification plugin disabled because I want the user to go directly to the checkout after they click on the Add to cart button. However, after updating Hikashop now when the user clicks on the Add to cart button nothing happens. There is a display notification that a product was added to the cart but that then disappears and the user is not redirected to the checkout and there is no way to get to the checkout. Prior to updating the user just clicked on the Add to cart button and they were then taken to the checkout. What setting am I missing?
2 years 4 weeks ago #363993 by nicolas
The add to cart system will automatically redirect to the checkout if nothing does something after the add to cart.
So, if the cart module updates itself, or the cart notification plugin does something, the add to cart system won't redirect to the checkout.
I suppose you might have the cart module on the page, and that's why there is no redirect.
The solution is actually to activate back the cart notification plugin. It has settings where you can choose to redirect the user to the checkout on success. This will force the redirect after the notification box is displayed by the plugin.
Time to create page: 0.042 seconds
