- Thank you received: 14322
Hikashop Cart Module on Drawer
Thank you for your feedback. I've made a patch which should fix the problem. Download again the install package of the 6.3.0 on our end and install it on yours to get it. You'll have to flush your browser's cache to see the change
On your website, I can see some of the changes I made, but some other changes are missing.
I suppose you have a view override on product / cart.
Rename temporarily the file templates/YOUR_TEMPLATE/html/com_hikashop/product/cart.php to something else via FTP in order to deactivate the view override and see if you still have the problem.
- Thank you received: 20
Je découvre cette fonction du panier 'tiroir" et je trouve cela très bien MAIS le popup de "Terminer votre commande ou continuez vos achats" vous empêche d'agir sur ce panier qui une fois répondu au popup disparait totalement. Si on détermine qu'il s'affiche à droite, ne doit-il pas être toujours accessible?
Je pense que j'ai du oublier quelque chose…
Merci
Je ne vois suis pas. Merci d'ouvrir un nouveau sujet et de fournir une URL et les instructions pour reproduire le problème.
nicolas wrote: Hi,
Yes, sorry, I didnt expect that you change this file.
But, now there is another issue
Put one product to cart, close it. Then put another product to cart, close it. Then open the cart (klick on cart) and remove one product.
Then click on cart. Should open the drawer, but it redirect to checkout.
And there is a shift of the header to the left when open drawer. I think that before was no shift.
I was indeed able to reproduce the issue with the drawer after a product is removed from the cart. I've worked on a patch and published a new build of HikaShop on our website. Download it and install it again to get it.
However, regarding the header shift when opening the drawer, I don't see it on your website. So I'm not sure what this is about. Did you already do something for it ? Can you double check ? Could you try with another browser ? Which browser are you using ?
Which version of Chrome are you using ? On which OS ?
Could you maybe do a video of the issue ? Maybe we're not talking about the same thing.
