Checkout not progressing and radio button issue
13 years 3 months ago #116067 by greenfreakman
I had my checkout working how i wanted but since updating both joomla 2.5 & Hikashop Business i have a couple of problems...
1/ When you select your chosen shipping method the basket updates and the available payment methods update accordingly (which is what i want) BUT the shipping method radio button does not show selected.
2/ After selecting the shipping & payment i click on the "Next" button to progress order to STATUS but it just refreshes the current page.
I have the latest versions installed com_hikashop_business_2.2.0_2013-07-28 and Joomla 2.5.13
Any ideas?, Kind Regards, Paul.
13 years 3 months ago #116070 by Jerome
Do you have an override of the view "checkout | shipping" ?
13 years 3 months ago #116085 by greenfreakman
Hi Jerome, i think this is it but not completely sure, apologies if it it's not. Paul.
13 years 3 months ago #116156 by Eliot
Hi there,
You can simply go in Display>Views and look for the checkout | shipping view and tell us if you made any modification here (there will be a little trashcan on the right if yes).
Also, a link to your website could help us to see the issue.
13 years 3 months ago #116220 by greenfreakman
I have sorted the problem although I don't know what the cause was. I reverted back to the un-modified checkout - shipping view and started over again. I think I may have made modifications in the past to the view that were no longer needed since your updates and so maybe some sort of conflict. (FYI My previous post has the old modified view attached)
Thanks for your help in pointing me in the right direction, Cheers, Paul.
