shipping method restrictions for products
9 years 3 weeks ago - 9 years 3 weeks ago #280966 by Lumiga
-- url of the page with the problem --
-- Joomla version -- : 3.8
-- PHP version -- : 7
Hi Hikashop Team,
My client have different products in their webshop and they sent only to their own country (Netherlands) and Germany. But some of the product categories may not shipped to Germany. How can we prevent these products from being shipped to Germany. But unfortunately
I see no restrictions in the manual shipping methods for products or product categories.
Is there another way we can handle this?
Hope to hear from you.
Kind regards,
Lumiga
P.S. It would be nice if we could have such a sort of options like Woocommerce where product categories and product classes would be very helpful or the Product-level Rules. See:
docs.woocommerce.com/document/woocommerc...-payments/#section-9
Kind regards,
Lumiga
Last edit: 9 years 3 weeks ago by Lumiga.
9 years 3 weeks ago #280972 by nicolas
There is.
You need to activate the "use shipping price per product" in your shipping methods.
Then, when you edit a product, you have a "shipping prices" area and there, for each shipping method, you can click on the + button and check the "block" checkbox and save the product settings and these blocked shipping methods won't be available on the checkout when that product is in the cart.
That way, you can restrict shipping methods to different zones and thus block products for some countries.
9 years 3 weeks ago #281090 by Lumiga
Thanks Nicolas,
But that's a lot of work to block 7 shipping methods for every product characteristic.
That's more than 2.000 clicks for me.
So I was looking for the Mass Actions and hoped that it will help to do this job for me.
But I can't find a table where this is stored in the database. Also when I do an export from a product with several shipping prices blocked I can't find the table either.
Hope you can give me a hint to find out how to automate this for all products in certain categories. ;-)
Kind regards,
Lumiga
Kind regards,
Lumiga
9 years 3 weeks ago #281094 by nicolas
You don't need to do it for each variant of a product. You can do it for the main product and it will apply to all the variants of the product.
The shipping prices per product are not stored in the hikashop_product table and there is no mass action on it.
You can check the hikashop_shipping_price table via your phpmyadmin.
You can export it as a CSV, edit it with excel and import it back.
That way, you can add entries to it rapidely.
9 years 2 weeks ago #281168 by Lumiga
Thanks Nicolas,
I will try to do the CSV trick ;-)
For your information. I have tested this several times, but in the most cases you have to set te variants by your self. Sometimes only the default variant is set right. But most of the times it's not set to the variants and you have to do it by yourself.
Kind regards,
Lumiga
Kind regards,
Lumiga
9 years 2 weeks ago #281172 by nicolas
Thanks for the feedback.
Change the code:
$product_ids = array_keys($shipping_price->products); JArrayHelper::toInteger($product_ids);
$product_ids = array(); foreach($shipping_price->products as $product){ $product_ids[] = (int)$product->product_id; }
in the file administrator/components/com_hikashop/helpers/helper.php and that should fix the issue with the main product shipping prices not taken into account on the frontend because of some changes we've made in the cart system with HikaShop 3.
Let us know how it goes.
9 years 2 weeks ago #281476 by jouwnaambord.nl
Same issue here, tried to change this code in helper.php. Didn't work, there seems to be a codeproblem, the site freezes in step 3.
kind regards,
Michel
9 years 2 weeks ago #281479 by Jerome
Please details your issue and your context.
Unfortunately, we do not know what is "step 3", not your website, version number, configuration, etc.
Nicolas proposed a patch but we did not get any return from "Sailfin73" so we can't tell you right now if it solve the problem.
9 years 2 weeks ago #281513 by jouwnaambord.nl
Hi Jerome,
Well, I changed the code:
as Nicolas suggested in the file helper.php. There must be an error in the code as the screen turns blank on the checkoutstep where the shippingmethod is presented. Obviously I restored the code to have the site work properly. URL therefore is not usefull, as the helper.php file is again the original one.
Joomla 3.8.1
Hikashop 3.2.0
PHP 7.0
9 years 2 weeks ago - 9 years 2 weeks ago #281515 by Lumiga
Sorry, but the code from Nicolas doesn't fixed the issue. I still have to do all the variants one by one after I set the main product.
I get no freezes or errors like michelpouli when I walk through the checkout process.
Kind regards,
Lumiga
Kind regards,
Lumiga
Last edit: 9 years 2 weeks ago by Lumiga.
9 years 1 week ago #281875 by Jerome
I set-up a test environnement for that case and my conclusion for the patch is really different than the one proposed by Nicolas.
It is important to keep the "array_key" to get the product_ids since the structure hasn't changed with HikaShop 3 and it's not related to the new cart system.
Here the modified code :
foreach($order->shipping_prices as $key => $shipping_price) { if(empty($shipping_price->price_per_product) || empty($shipping_price->products)) continue; $shipping_ids = array_keys($shipping_price->price_per_product); JArrayHelper::toInteger($shipping_ids); $product_ids = array_keys($shipping_price->products); $query = 'SELECT a.shipping_id, a.shipping_price_ref_id as `ref_id`, a.shipping_price_min_quantity as `min_quantity`, a.shipping_price_value as `price`, a.shipping_fee_value as `fee` '. ' FROM ' . hikashop_table('shipping_price') . ' AS a '. ' WHERE a.shipping_id IN (' . implode(',', $shipping_ids) . ') '. ' AND a.shipping_price_ref_id IN (' . implode(',', $product_ids) . ') AND a.shipping_price_ref_type = \'product\' '. ' ORDER BY a.shipping_id, a.shipping_price_ref_id, a.shipping_price_min_quantity'; $db = JFactory::getDBO(); $db->setQuery($query); $ret = $db->loadObjectList(); if(empty($ret)) continue; $products_qty = $shipping_price->products; foreach($order->products as $ordered_product) { if($ordered_product->product_parent_id == 0) continue; foreach($ret as $ship) { if($ordered_product->product_id == $ship->ref_id) { $products_qty[ (int)$ordered_product->product_parent_id ] -= $products_qty[ (int)$ordered_product->product_id ]; } } } foreach($ret as $ship) { if($products_qty[$ship->ref_id] > 0 && $ship->min_quantity <= $products_qty[$ship->ref_id]) { $order->shipping_prices[$key]->price_per_product[$ship->shipping_id]['products'][$ship->ref_id] = ($ship->price * $products_qty[$ship->ref_id]) + $ship->fee; } } unset($products_qty); }
9 years 6 days ago #282081 by jouwnaambord.nl
Hi Jerome,
Yes this seems to work. But now there's a warningmessage: "There are items in your shoppingcart that can't be shipped to you."
And there's one more thing: I have a paymentmethods connected to the shippingmethods and they still show when the shippingmethod doesn't.
9 years 6 days ago #282091 by Mohamed Thelji
In that case, we'll need more information through some screenshots for example about how you configured your :
- Products
- Shipping method(s)
- Payment method(s)
9 years 5 days ago #282181 by Lumiga
Hi Jerome,
I changed this code in the file administrator/components/com_hikashop/helpers/helper.php
to your code:
See screenshot:
But that didn't fixed the issue that you can do it for the main product and it will apply to all the variants of the product.
It looks like one variant (the first one) is updated but not all the other variants.
But one the second test it looks like only the last variant is updated. So that really strange!!!
P.S. I don't get an warningmessage like michelpouli. I have no issue with shipping and paymentmethodes and shippingmethods showing at the checkout. In my case it's working fine.
There is another issue but that's only related to this issue. Because when I have a product in my cart which may not be sent to Germany (in my case) then I get as shipping address the address from the shop and not from the Germany address. But that's fine!. So when I delete the specific product which may not be sent to Germany, then still the address from the shop is displayed as the shipping address. To fix this I have to go first to step 3 and then select a shipping method and then I have to go back to step 2 to see my address with the option to change it. But that's not really user friendly I think.
I hope you find a solution for both issues. ;)
Kind regards,
Lumiga
Kind regards,
Lumiga
9 years 5 days ago #282219 by Jerome
I'm sorry but you did not replace the code at it should.
In the screenshot we can see twice the line
So it means that you add some content and not replace it.
Best for you would be to re-download the HikaShop 3.2.1 package.
