- Thank you received: 2
Australia Post | Shipping Method does not display
- thomas.boepple
9 years 1 week ago - 9 years 1 week ago #281607
by thomas.boepple
Australia Post | Shipping Method does not display was created by thomas.boepple
niagaraparkit.com/oztimber/index.php/hik...ies-listing/checkout
-- Joomla version -- : 3.8.1
-- PHP version -- : 5.6.98
I have setup 3 shipping methods in the backend.
Australia Post shipping plugin V2 ( API is entered)
Australia Post shipping plugin (deprecated) - I did this for troubleshooting
manual shipping plugin
From the 3 plugins I only get 'manual shipping' to display on the front end.
All 3 are published.
What am I missing?
'looking forward to your assistance.
Best,
Thomas Boepple
NiagaraIT
What am I missing?
Best,
Thomas Boepple
NiagaraIT
Last edit: 9 years 1 week ago by Jerome.
9 years 1 week ago #281650
by Jerome
Replied by Jerome on topic Australia Post | Shipping Method does not display
Does your products have correctly set-up values for their weight and dimensions ?
The following user(s) said Thank You: thomas.boepple
- thomas.boepple
9 years 1 week ago #281688
by thomas.boepple
Replied by thomas.boepple on topic Australia Post | Shipping Method does not display
Hi Jerome,
I have configured 1 product with dimensions and weight for testing purposes.
Product is
www.niagaraparkit.com/oztimber/index.php...roduct/1-burl-bowl-1
This is the one I am testing on and on which I only see the manual shipping option.
I am going to add weight and dimension to the others I have up there as well now - just to see if it triggers the shipping plugin.
My steps are:
go to product page > add to cart > go to checkout > login or continue as guest.
There I only see the manual shipping.
Attached is a screenshot of the product page - backend
Australia Post shipping - backend.
Thanks,
Thomas
Product is
My steps are:
Thanks,
Thomas
- Thank you received: 1778
9 years 1 week ago #281712
by Mohamed Thelji
Replied by Mohamed Thelji on topic Australia Post | Shipping Method does not display
Hello Thomas,
I just tested it on your website and the Australia Post shipping was correctly displayed after I entered my shipping address. Did you fix your issue ?
- thomas.boepple
9 years 1 week ago #281807
by thomas.boepple
Hi Mohamed,
thanks for checking.
Yes, the issue is resolved.
The plugin kicks in as soon as the address is entered.
I also unpublished the manual shipping plugin, so there is no confusion now.
All the best,
Thomas
All the best,
Thomas
- thomas.boepple
9 years 1 week ago - 9 years 1 week ago #281809
by thomas.boepple
Only one small issue left - with the manual shipping unpublished the system now displays an error message on login ( screenshot attached), stating 'no shipping method found.
While I guess this is technically correct since Australia Post has not been triggered yet it still is confusing to the user.
How do I get rid of the error message?
Last edit: 9 years 1 week ago by thomas.boepple. Reason: spello
9 years 1 week ago #281835
by Mohamed Thelji
Your issue is coming from the fact that you have the login/address actions on the same step that the shipping action is in.
The solution will just be to make sur tat these actions are not in the same step (login&address before shipping).
