- Thank you received: 2
Authorize.net connection problem
- fullfusion
14 years 3 months ago #59399
by fullfusion
Authorize.net connection problem was created by fullfusion
I'm working on setting up a new store for a client and when testing I get this system error:
"The connection to the payment plateform did not succeed. It is often caused by the hosting company blocking external connections so you should contact him for further guidance."
I've talked to my host (Rackspace) and they said that port 443 is open, they aren't see any errors in their log when I test it, and they don't see any other issues would be be preventing this from connecting. What else could be the issue here?
14 years 3 months ago #59451
Replied by nicolas on topic Re: Authorize.net connection problem
It could potentially be that you changed the URL option of the authorize.net plugin to something else which is not correct.
Other than that, I don't see anything else that could produce such problem.
- fullfusion
14 years 3 months ago #59454
by fullfusion
Replied by fullfusion on topic Re: Authorize.net connection problem
What should it be set to when using AIM?
14 years 3 months ago - 14 years 3 months ago #59456
https://secure.authorize.net/gateway/transact.dll
Last edit: 14 years 3 months ago by nicolas.
- fullfusion
14 years 3 months ago #59457
by fullfusion
That's what I was missing. Thank you!
