Custom Payment Method, problem with cancellation of orders
- brendanlanza
9 years 2 months ago - 9 years 2 months ago #276086
by brendanlanza
biosinar.com
-- Joomla version -- : 3.7.4
-- PHP version -- : 7.0.22
Hi guys,
I am developing a custom payment method for Hikashop. a couple of things are not working.
1. When i use this line in my code for function onPaymentNotification(&$statuses)...
Two things happen ie
a) It does NOT change the order status to the defaut for cancellations ie CANCELLED, instead the order remains as CREATED
b) It prevent a redirect to the cancel_url, instead the user is brought back to the last stage of the shopping cart
If I replace the same line with this
Everything works, but of course, that line makes cancelled orders become CONFIRMED. It also takes the user to the right cancel_url.
Here's the relevant codes
Hi guys,
$this->modifyOrder($order_id, $this->payment_params->invalid_status, true, true);
//$this->modifyOrder($order_id, $this->payment_params->verified_status, true, true);
if($vars['EXECCODE'] != 0000)
// Here we display debug information which will be catched by HikaShop and stored in the payment log file available in the configuration's Files section.
//print "EXECCODE is non-zero";
if($this->payment_params->debug)
print 'payment '.$vars['MESSAGE']."\n\n\n";
// This function modifies the order with the id $order_id, to attribute it the status invalid_status.
//To redirect the user, if needed. Here the redirection is useless : we are on server side (and not user side, so the redirect won't work), and the cancel url has been set on the payment platform merchant account
$this->app->redirect($cancel_url);
return false;
//If everything's OK, the payment has been done. Order is validated -> success
else
//print "All OK";
$this->app->redirect($return_url);
return true;
Last edit: 9 years 2 months ago by Jerome. Reason: using [code] tag to display code
9 years 2 months ago #276092
Replied by nicolas on topic Custom Payment Method, problem with cancellation of orders
The modifyOrder function doesn't do any redirection.
It does only two things:
- it saves the new order status by calling the save function of class.order
- it sends the payment notification email to the administrator
If the status is not changed, then either there is a problem with the rest of your code when you test it, or there is another plugin, implementing the onAfterOrderUpdate or onBeforeOrderUpdate triggers (which are called during the saving of the order) which does something it shouldn't.
And more specifically, the onBeforeOrderUpdate trigger has a $do parameter which can cancel the change of the order status. So a plugin can cancel your modification of the order status for some reason.
For example, if you've configured a mass action to change the status of orders that are being cancelled to created, the mass action plugin will be able to cancel you order status change.
Also, if such plugin does a redirect, the redirect stops the processing of the page and anything after the redirect will be skipped.
So if a plugin implementing the onBeforeOrderUpdate trigger does a redirect, it will skip the save of the order and your own redirect.
- brendanlanza
9 years 2 months ago - 9 years 2 months ago #276162
by brendanlanza
Replied by brendanlanza on topic Custom Payment Method, problem with cancellation of orders
Thank you Nicholas. After doing some checking, I found out that the following line of code based oncallback in the Example Payment Method does not work and has to be replaced with the second. Then it works.
First, set the return and cancel URLs to make callbacks to
Then implement the return value in a GET variable to be returned to the return URL
Finally, make the callback making sure that both the success and cancel calls be made to the return_url and DO NOT use the Cancel_url
Now it works.
I have now encountered another, different problem but I'll raise another issue on that matter.
$qrystr = $_SERVER["QUERY_STRING"];
$actionok = "http://unicomms-emall.com/index.php?option=com_hikashop&ctrl=checkout&task=n"."otify¬if_payment=unicommspayment&tmpl=component&".$qrystr;
$actionnok = "http://unicomms-emall.com/index.php?option=com_hikashop&ctrl=order&task=cancel_order&".$qrystr;
if ($_REQUEST["choiceLst"] == "Ok")
$actionurl = $actionok . '&EXECCODE=0000'; //Signifies that the trasaction is okay
else
$actionurl = $actionok . '&EXECCODE=9999'; //Signifies that the transaction is rejected
9 years 2 months ago #276165
by Jerome
Replied by Jerome on topic Custom Payment Method, problem with cancellation of orders
Please use the code tag to post code.
Thank you for your understanding.
