is it possible use multi payment method.
2 years 6 months ago #360489 by sadaf3d
hi.
Is it possible use multi payment method as i describe in the following.
i have 3 different payment method instance A , B , C . i want use payment method A as a default payment for hikashop. use B for one vendor. and important of all use C for vendor who has not set in that.
In fact, I want to use C for vendor products that are not assigned to a specific payment method, and use method A for normal site products that are not related to any vendor. It is obvious that I select a desired vendor in the B settings and with this method I can assign payment method B vendor to all the products under that vendor B, which is not a problem in this field. The main problem is that in the way it was said, is C usable?
2 years 6 months ago #360497 by Jerome
Yes, once you have HikaMarket installed, you will find new settings for you payment methods in your HikaShop backend.
These settings allows you to assign a payment method to a specific vendor or to a group of vendors.
Only payment methods of the vendors are available during the checkout.
If payment methods don't have restriction, they will be available for every vendors ; except if you use the corresponding HikaMarket Setting : www.hikashop.com/support/documentation/1...onfig_market_general
Please note that you'll need to limit the number of the vendors in the cart to 1 ; but you still need to use the "market mode" called "store paid directly" since you'll be able to override that setting directly in the payment method settings.
So, only when specific vendor payment are used, HikaMarket will know that the vendor is being paid directly and that the vendor will have to pay you back your fees.
2 years 6 months ago - 2 years 6 months ago #360513 by sadaf3d
1-How do I assign a payment method to a group of vendors in the following link?
demo.hikashop.com/administrator/index.ph...nt_edit&payment_id=4
2-is it possible create group of vendors? i can't see such setting.
3-I will explain my need a little more simply:
I have three payment methods in Hikashop.
I have not assigned payment method 1 to any vendor.
I have assigned payment method 2 to vendor A.
Payment method 3, like 1, I have not assigned to any vendor.
I want to implement this scenario:
If the user wants to buy the normal Hikashop product that is not assigned to any vendor, payment method 1 should be applied.
If the user wants to buy the product related to vendor A, payment method 2 should be applied.
If the user wants to buy the product related to vendor B, payment method 3 should be applied. My problem is exactly in this third part. Vendor B has a product but no payment method is set for him.
Last edit: 2 years 6 months ago by sadaf3d.
2 years 6 months ago #360525 by Jerome
1 - Sorry, the "Vendor group" is implemented for the Shipping methods but is not available for Payment methods since a payment method is more "private" since it allows to send money to a specific account (and specific credentials).
2 - Vendor groups are Joomla groups.
You can assign a vendor to a group, in the tab with the ACL.
It was first used to simplify the ACL configuration, but it can also be used for shipping method assignation (but sorry, I was mistaken with the payment methods).
3 - Payment without a vendor assignation will be displayed for any vendor or only your store depending on the setting "Show only vendor payments".
In your scenario, "Payment method 1" and "Payment method 3" are not assigned to a vendor ; thus they will have the same behavior in HikaMarket : be displayed to your store (or to every vendor if you do not have the mentioned setting).
If you want to show "Payment method 3" for "Vendor B", you have to edit that payment method and modify the "Vendor Options > Vendor" setting.
The following user(s) said Thank You: sadaf3d
