- Thank you received: 1
Filter Product Problem
14 years 5 months ago #51926
by Darken
Filter Product Problem was created by Darken
I am having problem doing searching of products on backend. For example the product name is "ESS CrossBow Lenses". In the past I can type the full name into the filter box and search for it and it will appear. However, out of sudden it can't work if I type in the full name and search. I must only type in "ESS" and the result come out with a whole bunch of other products.
Does anyone know why is that?
14 years 5 months ago #51980
Replied by nicolas on topic Re: Filter Product Problem
Did you do something between before when it was working and now ?
14 years 5 months ago #51989
by Darken
Replied by Darken on topic Re: Filter Product Problem
oh i think i solved the problem. it is because of the newer hikashop version that had the filtering options for "product category" and "brands" on the top of the page. You would have to press "reset" to make sure all fields are at default to make searching of the full name "ESS CrossBow Lenses" work.
