Characteristics and Product Images Problem
14 years 2 months ago #65137 by Pit Pony
I am testing the latest hikashop update on a dummy of my site before applying it to the live site...
Where I have a Product where a user can select different characteristic (eg the length of a fence post: 1.2m, 1.5m, 1.8m) I am getting duplication of the products image below the product description.
If a Product has four characteristic options I will get four duplicates of the Product image in a vertical list
14 years 2 months ago #65144 by Mohamed Thelji
Can you send me screenshots of this and the link of your website ?
14 years 2 months ago #65157 by Pit Pony
The link to a product on the live website
www.tswservices.co.uk/staplelok-fencing-...ory_pathway-101.html
Attached a screenshot of the same page on a wampserver after the latest hikashop date
14 years 2 months ago #65300 by nicolas
The link you provided doesn't work. Could you double check the URL please ?
14 years 2 months ago - 14 years 2 months ago #65311 by Pit Pony
tswservices.co.uk/staplelok-fencing-system/staplelok-fencing-components-and-parts/product/554-staplelok-system-fencing-post.html
Last edit: 14 years 2 months ago by Pit Pony.
14 years 2 months ago #65511 by nicolas
I checked that page but I don't see any image duplication below the main image.
Can you do a screenshot of what you see ?
Did you try with another browser ?
14 years 2 months ago #65900 by Pit Pony
The link I sent would not show errors as I did not want to upload the latest version of hikashop onto the live site until I had found a solution...
In a previous posting I sent a screenshot of the errors that occur when I tested hikashop 1.6 on a local version of wampserver...
I have now updated the live site to hikashop 1.6, so if you try the link again you will see the problem...
14 years 2 months ago #66013 by nicolas
It seems to come from the fact that you had overrode the file show or the file show_block_img of the view product via the menu Display->Views so you didn't get the new modifications for these views.
You should try to remove these modifications via the menu Display>Views and reapply them on the new version of the view file.
14 years 2 months ago #66105 by Pit Pony
Have now sorted image duplication... :-) but in doing so I can foresee a problem as hikashop develops new features...
I have overrode many views in my site, these views are obviously protected from being over written in an update...
If a new feature is added to a view file in an update that has previously been overrode, I will not be able to see the new feature until I have reapplied my modifications to the new version of the view file ...
I apologies if I have overlooked it, but is a list of altered views and associated new features published at the time of each upgrade...
14 years 2 months ago #66361 by nicolas
There is no such list.
For such big update as we did with the 1.5.9-1.6.0, almost all the views on the front end have been changed in some way.
Usually, we try to keep backward compatibility, so you don't have problems when you update, even though you don't get the new features.
With the badges feature, we had to modify the images display in a way which couldn't be backward compatible, thus the problem you had.
