Group options with product does not always work
13 years 3 months ago #116749
by peters
Group options with product does not always work was created by peters
if I add a product (which has product options) to the cart, but do not select any option (all options are set to "no")
and after
I add the same pruduct with a select option. the 2 product will not be grouped (i have enabled [Group options with product])
When I do the same conversely. 1) product with an selected option and 2. the same product with no option, it works
see attachments
and after
see attachments
- Thank you received: 1778
13 years 3 months ago #116789
by Mohamed Thelji
Replied by Mohamed Thelji on topic Group options with product does not always work
I just tested it on my end and it seems to be working fine, so can you download the last Hikashop version, install it and test it again ?
13 years 3 months ago #116814
by peters
Replied by peters on topic Group options with product does not always work
same issue with the actual version
13 years 3 months ago #116851
Replied by nicolas on topic Group options with product does not always work
Can you provide a link to your product page so that we can see that ?
13 years 3 months ago #116860
by peters
you have PM
13 years 3 months ago #117036
Thank you for the access.
I think I found the solution. Please change the file administrator/components/com_hikashop/classes/cart.php with the one in the archive enclosed and that should fix the problem.
13 years 3 months ago #117053
by peters
Problem solved! many thanks.
The system does not summed products with options - it lists it separately.
I think this is OK:
- Products without options are summed.
- Products with options are listed separately (even if the same options were selected).
I think this is OK:
