Sort products by code - Wrong label
6 years 6 months ago #319106 by xatzopou
In this chatzigeorgiadis.gr.185-138-42-46.linuxz...erver.gr/en/products URL when you click to Sort products by code a label "PRODUCT_product_code ascending" shown.
I tried to find and correct this in the language file but I couldn't.
Best regards,
6 years 6 months ago - 6 years 6 months ago #319108 by Philip
There is a good chance that it come from your language file, You can look in your translation file in order to correct this, see This tutorial .
OR you can you try to update it, to see if that solve your issue.
Hope this will help you to solve your issue.
Last edit: 6 years 6 months ago by Philip.
6 years 6 months ago #319199 by xatzopou
can you tell me the language label for the "product code ascending" in order to change the text?
The one shown when you select a "sort by product's code" filter.
Best regards.
Makis
P.S. I test it with other hikashop's installations and see the same error.
6 years 5 months ago #319313 by nicolas
Thanks for your feedback. I was able to reproduce the issue on my end and added a patch for it.
Download again the HikaShop Business install package on our website and install it on yours and you'll get the patch for that.
