Problem with add to card on IE8
15 years 8 months ago #9172 by Darkos17
I have a small problem with add to card on IE8.
Pleas look to the avi file.
15 years 8 months ago #9173 by nicolas
Could you do a screenshot of the tab checkout of the configuration of HikaShop ?
Also, do you have the joomla cache activated ?
www.theartofjoomla.com/joomla-caching-explained.html
15 years 8 months ago #9185 by Darkos17
Thank you for your reply very much.
The joomla cache is off.
image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/checkout.gif
I forgot about one detail.
Normally it works great in IE8.
But try:
1. create account,
2. login to the new account with option "remember me"
3. try to buy something ==> the problem is appearing.
15 years 8 months ago #9200 by nicolas
We couldn't replicate the problem on our end with the same settings (ie8, joomla 1.5, new account->login with remember me->try to buy on a product page). However, that kind of problem is usually caused by the cache of the module by joomla. Could you make sure that the system cache plugin is disabled as well as the cache config on your configuration ?
15 years 8 months ago #9222 by Darkos17
Could you look to my site?
www.dobrycad.pl/
I will send you login and password in privet message.
Thank you in advance.
15 years 8 months ago #9229 by nicolas
I just tried on your website and didn't had the problem either. It worked as expected. It worked while logged in with the remember me, without it, logged out, etc.
I used IE 8.0.6001.18828
Do you have the problem on your end with the account you gave me ?
Time to create page: 0.156 seconds
