Issue with utilizing alphauserpoints for payment
14 years 1 month ago #59121 by mj
Hi, I have the latest version of alphauserpoints 1.7.4 on joomla 2.5.4 with hikashop 1.5.8.
I attached a screenshot of the alphauserpoints settings as well as how the shopping cart looks on checkout. I want to set it up so that users can only pay with alphauserpoints, however it doesn't display that payment option. I have a test user setup which already has points to purchase items with. I setup the paypal payment plugin for testing purposes (if disabled, it says no payment option available).
Do I have something setup improperly?
14 years 1 month ago #59218 by nicolas
Could you do a screenshot of the options of the AlphaUserPoints payment method and make sure that it is published ?
14 years 1 month ago #59329 by mj
Here it is sorry, I attached the wrong file
14 years 1 month ago #59349 by mj
And the plugin is published..
14 years 1 month ago #59352 by mj
My developer put in some echos into the hikashop payment plugin into alphauserpoints in several areas to see where it was breaking. It's saying it can't find the file while checking if it exists, while all other alphauserpoints functionality still works in other components, just not hikashop. Here's a screenshot of the echo.
14 years 1 month ago #59353 by mj
This is after the function "onPaymentDisplay" in the alphauserpoints.php file
14 years 1 month ago #59414 by nicolas
Please remove the zone restriction and the currency restriction from the AlphaUserPoints plugin. Then, make sure that you also set a big maximum number of points (MAXIMUM_POINTS option).
Then, make sure that your user has enough points (more than 10 times the total amount in dollars since 1 points = $0.1) or turn on the "partial payments" option of the AlphaUserPoints plugin.
Also please note that payment methods never display if the order total is 0. I see that you have a free product in your last screenshot, so in that case, it's normal that payment methods don't display.
14 years 1 month ago #59508 by mj
Thanks for the help. I've adjusted the settings as shown in the attached image. However, it's still having the same problem. I tried it with an item that cost $1 using those settings, and it still displays no payment method.
14 years 1 month ago #59564 by nicolas
That looks good.
Can you check that the AlphaUserPoints plugin is enabled ?
Also, make sure that the "Order_validation" rule which is added by the plugin automatically is published in AlphaUserPoints
14 years 1 month ago #59588 by mj
I checked on both of those, they are enabled.
14 years 1 month ago #59805 by nicolas
I don't have any other ideas. I've stated all the possible causes I know for that issue. It must be one of them.
If you provide an access to your back end I can have a look at your settings.
14 years 1 month ago #60133 by mj
I messaged you the backend information for the website, can you please take a look?
14 years 1 month ago #60206 by nicolas
The problem was that you had no points for the admin user and the fact that you were using a decimal points to usd rate so the points were not calculating properly and the fact that you had added the code to display messages and not continue the processing in the plugin.
It's working fine now.
14 years 1 month ago #60305 by mj
Perfect! Thank you so much Nicolas, you're a life saver!
Time to create page: 0.249 seconds
