Problem in integrating plugin in needcc function
13 years 3 months ago #117817 by sanjivani1812
-- HikaShop version -- :2.2.0
-- Joomla version -- : 3.0
-- PHP version -- : 5.1
I'm using hekashop component. And I've got 2 issues in it.
My first problem is,
I made a plugin for hekashop payment plugin. I want to display custom html form and show amount & currency in hidden fields in function needcc.
I can display custom form, but I'm unable to display the amount and currency in hidden fields..
And second thing,
When I submit credit card custom form, it stays on same page.
Expected: It should redirect to next step.
Please look over the issue, and provide me appropriate solution as early as possible..
Thanks,
Sanjivani
13 years 3 months ago #117855 by Mohamed Thelji
If you're the one who developed your payment plugin you should probably show use your code, then we'll be able to fix together :).
