- Thank you received: 22
pdf attach invoice layout problem
- jouwnaambord.nl
5 years 10 months ago #327970
by jouwnaambord.nl
pdf attach invoice layout problem was created by jouwnaambord.nl
-- Joomla version -- : 3.9.23
-- PHP version -- : 7.4
I just purchased the latest attach pdf invoice plugin. For some products (or options) the textline is longer. This breaks the pdf layout, see screenshot. In the "old" plugin I didn't have that problem. How can I solve this?
5 years 10 months ago #327974
Replied by nicolas on topic pdf attach invoice layout problem
From what I can see, the issue comes from the name of the option which is too long.
There is already code to avoid that for the product name, but there is indeed no code to handle that for options.
However, that was never the case, so you must have had the same issue before but never noticed.
To fix that, change the code:
in the file plugins/hikashop/attachinvoice/attachinvoice/invoice.php
echo $optionElement->order_product_name;
if($optionElement->order_product_price>0 && !$this->shipping_invoice){
if($config->get('price_with_tax')){
echo ' ( + '.$currencyHelper->format($optionElement->order_product_price+$optionElement->order_product_tax,$order->order_currency_id).' )';
}else{
echo ' ( + '.$currencyHelper->format($optionElement->order_product_price,$order->order_currency_id).' )';
$option_name = $optionElement->order_product_name;
$option_name .= ' ( + '.$currencyHelper->format($optionElement->order_product_price+$optionElement->order_product_tax,$order->order_currency_id).' )';
}else{
$option_name .= ' ( + '.$currencyHelper->format($optionElement->order_product_price,$order->order_currency_id).' )';
echo '<p>'.implode('<br/>', $this->str_split_unicode(strip_tags($option_name),50));
- jouwnaambord.nl
5 years 10 months ago #327987
by jouwnaambord.nl
Replied by jouwnaambord.nl on topic pdf attach invoice layout problem
Thanks for your solution. There must be some small mistake in the code, after changing I get the errormessage: "1 Tags are closed in a wrong order for [td]"
5 years 10 months ago #327988
Ah yes, the line :
should be:
echo '<p>'.implode('<br/>', $this->str_split_unicode(strip_tags($option_name),50)).'</p>';
Ah yes, the line :
should be:
The following user(s) said Thank You: jouwnaambord.nl
- jouwnaambord.nl
5 years 10 months ago #328032
by jouwnaambord.nl
Yes, thank you, this works fine!
