Problem with custom plugin
9 years 9 months ago #260719
by tvikito
Problem with custom plugin was created by tvikito
-- HikaShop version -- : 2.6.4.
-- Joomla version -- : 3.6.5
-- PHP version -- : 7.0.5
Hi guys!
I have just rewrite your Hikashop google products plugin for another product search provider. I was developing it on one of my localhost and successfully made it works. But when I installed it on live site something went wrong. Installation - no problem, enable and set up plugin - no problem, but when I want to download manually xml file there is problem. And absolutelly don't know why, because on first localhost where I developed it is working, but on live site and even on other localhosts not... My plugin is here in attachments.
If you can just look what my problem is, I would be really grateful! Thanks!
Hi guys!
9 years 9 months ago #260757
by tvikito
Replied by tvikito on topic Problem with custom plugin
Ok, now I know where can be the problem. I have copied install componet files com_hikashop_2.6.4 and added my custom plugin - added to back/extensions/plg_heureka_products and to update file back/helpers/update.php. And with this package I upgraded existing Hikashop. So my plugin was added as well and it's working. So problem is just with way of how to install it...
I guess that I am just missing one more thing - where else get Hikashop know about my custom plugin to make it works?
Right know I can do the same on my live site and it will works, but I would prefer (even for the future custom plugins) how install just plugin without need to upgrade whole component...
9 years 9 months ago #260760
by Jerome
Replied by Jerome on topic Problem with custom plugin
Just install your plugin via Joomla.
And let Joomla structure load the plugin and make it interact with HikaShop.
9 years 9 months ago #260836
by tvikito
Hi Jerome,
I worked it out. It was some bug with my Hikashop. After reinstall it works like it should.
Thanks!
Thanks!
