I create a plugin for add custom js in product page but i have a problem
8 years 7 months ago - 8 years 7 months ago #290180 by Krok
Hello ! I create a plugin for add custom javascript in product page but the javascript code added by Factory::getDocument()->addScriptDeclaration(/*Script set in a field*/); is add ~250 times in same page :O because the onHikashopBeforeDsiplay view is trigger many times, and i don't know how to solve this problem can u help me pls ?
My php code:
public function onHikashopBeforeDisplayView (&$view) { $plugin = JPluginHelper::getPlugin('hikashop', 'CustomJs'); $plg_params = new JRegistry(); $plg_params->loadString($plugin->params); $user = Factory::getUser(); $dom = Factory::getDocument(); if($view->getName() === 'product' && $view->getLayout() === 'show_quantity') { if(intval($plg_params->get('allow')) === 1) { $dom->addScriptDeclaration($plg_params->get('javascript')); } } }
In attachment, u can see what i have in the <script> tag inside the <head>
Attachment not found
Last edit: 8 years 7 months ago by Krok.
The following user(s) said Thank You: alin
8 years 7 months ago #290181 by nicolas
I'm surprised that the trigger would do anything at all with your code.
That fonction is called by the main view. So for example product / listing.php or product / show.php and not for the sub view files called within the main view file.
So normally, you should never have the condition $view->getLayout() === 'show_quantity' valid in your plugin.
Are you sure that the js code you're looking at comes from the PHP code you gave in your message ?
8 years 7 months ago - 8 years 7 months ago #290192 by Krok
Hello nicolas,
yeah i'm sure this js code is from the field in the configuration page of my plugin.
I've the same problem with my component for customize products, the html code was duplicated many times but I've solved this problem by creating a page for the component
8 years 7 months ago #290235 by nicolas
Well, if you're sure, you can always add such code:
static $done = false; if(!$done){ $done = true; }else{ return; }
That way, the code after this code will only run once on each page.
