- Thank you received: 3
click on cart icon and redirect to cart
2 years 3 months ago #362225
by diacotm
click on cart icon and redirect to cart was created by diacotm
-- Joomla version -- : 5.1.2
-- PHP version -- : 8.1.13
Is it possible to click on the mini cart main link which consists of an icon and directly proceed to the checkout page instead of opening a drop-down in mobile view?
Thanks in advance
Thanks in advance
2 years 3 months ago #362230
Replied by nicolas on topic click on cart icon and redirect to cart
Normally, it's easy to do. Edit the settings of the HikaShop cart module via the Joomla modules manager, and change the "mini cart" setting from "dropdown" to "yes".
However, I see that your module is customized. So it might require something else for this to happen.
But that's the first thing I would recommend to try.
If that doesn't help, we'll need a link to the shop in order to check on the situation.
2 years 3 months ago #362234
by diacotm
Replied by diacotm on topic click on cart icon and redirect to cart
Perfect!
Thanks tons of time
Thanks tons of time
