help with filters and searching
14 years 6 days ago #67706 by itye2012
I hope someone can help. I'm trying to create a filter which searches all my products on a keyword or partial keyword or wildcard. The results are then displayed with the photos of the products.
Ive tried to create a filter but unless you are in the actual category to do the search it returns nothing. I have to go into the the category where the products are to search and then it displays the results. I want to be able to search when not in a category itself eg on the front page and not inside any category.
Has anyone got some step by step instructions to help me create this?
14 years 6 days ago #67716 by Mohamed Thelji
I think that you'll just have to use/publish the "HikaShop Filter Module" through "Control Panel->Module Manager"
Hope this will help you.
14 years 6 days ago #67751 by itye2012
The module is published.
I created a new filter . the filter appears ok on my main page. If I search for beans for example nothing is returned.
However if i click into a category, eg tins category where the beans are then do the search it works?
I want to be able to search from my home page without needing to go into a category to search, is this possible?
14 years 5 days ago #67908 by nicolas
Yes, that's possible.
in the "menu" option of the module, you need to enter the id of a products listing menu which lists all your products and that will do it.
14 years 4 days ago #67953 by itye2012
thanks for the reply , with regards to the id of a products listing menu, where can I find/edit or create this listing menu
Many Thanks
14 years 3 days ago #68125 by nicolas
If you us the latest version of HikaShop there is already such menu in the hikashop default menus that you will found via the joomla menu joomla.
Otherwise, you will have to create it yourself:
www.hikashop.com/en/support/documentatio...d.html#products_menu
14 years 1 day ago #68345 by itye2012
I cant work out how a filter is being used on my page. to help me diagnose my search problems i disabled the hika shop filter module and the Hika shop products search module but i still get the filter found at the page below despite the hika shop filter module being disabled and the Hika shop products search module being disabled :-
you can see the filter here : www.britishfoodabroad.co.uk/index.php/products
This filter is published in the filters section of the hika shop menus. are these filters separate from the hika shop filter module and Hika shop products search module? if so what are the differences betweeen all these filters as it seems quite confusing. How is it showing on my page, i cant work out how?
also how can you clear the text in the filter when you revisit the page?
14 years 1 day ago #68550 by nicolas
The filters are displaying automatically on top of the product page. There is no need to have the filters module for that.
On top of their display on top of the product page, you can also display them anywhere on your website thanks to the hikashop filter module.
If you don't want them at the top of the menu, you can just hide them with CSS as explained in the documentation of the filters:
www.hikashop.com/en/support/documentatio...-filter-listing.html
On the other end, if you want to hide the filters on the main area of your page and only display the filters via the module, you can add such CSS (replace the X by the id of your menu) in the front end CSS file of HikaShop via the Display tab of the configuration :
#hikashop_category_information_menu_X .hikashop_filter_main_div{ display:none; }
14 years 1 day ago #68551 by nicolas
The filters will be cleared once your session on your website will be cleared.
You can control that delay with the corresponding option of the joomla configuration.
13 years 9 months ago #80375 by boussog1
I am trying to create a filter for the keywords as defined within each product. It works when I set the filter type to text. For any other type, the option keyword is not there. I would like the visitor to click on a keyword rather that have to type a keyword in the text field. Is there a way for the filter to produce a list of keywords?
Thanks in advance.
13 years 9 months ago #80444 by Jerome
You can pass filter parameters in the url. So you can create your keywords directly in HTML in the view.
Your keywords would have links to the product listing with an extra parameter for the filtering option, which would be "hardcoded" for each link.
13 years 9 months ago #80472 by boussog1
Thanks,
Is there no easier way through the existing filter module?
13 years 9 months ago #80553 by nicolas
There is.
Instead of using the default keyword field, you should create your own keyword custom product field via the menu Display->Custom fields. Make it a multiselect dropdown and select all the keywords for each product.
Then, in your filter select that custom field and the filtering system will automatically use the values of the custom field.
13 years 9 months ago #80751 by boussog1
Thank-you Nicolas. I did it as you suggested. Now where can I find the css for the filter, e.g. hikashop_filter_main?
13 years 9 months ago #80814 by Xavier
The css code for the filters is in HikaShop > Configuration > Display in the Frontend CSS File.
You can find some documentation onb how to styling the display here:
13 years 9 months ago #80914 by boussog1
Hi Xavier,
I have already looked there but there isn't any css for filters ...
13 years 9 months ago #81066 by nicolas
Yes, there is no CSS Applied on them by default. But that's where you can ADD your CSS code for your filters.
13 years 9 months ago #83193 by cosg2004
I got the business edition mostly for the filter and custom product field mostly.
Unfortunately the filter does not work:
1. I created and published the "price" filter.
2. Created the product_listing menu
3. Created and published the module with the menu Id as suggested in the docs.
When I click on filter it gets me to a new (search like) page but with no products displayed.
If I published the created menu and click on it, the products will show on a freshly open browser (Firefox on Ubuntu Linux).
Weird enough though, after I click on the filter (and doesn't give me anything), even if I click on the products_listing menu it doesn't display anything now. I have to re-start the browser in order to get the menu display products. The filter doesn't display anything regardless.
I can't provide you a link to the website yet as the website is still on my Ubuntu/Server machine for development.
Any ideas?
Thanks, Constantin
13 years 9 months ago #83363 by Mohamed Thelji
Hi Constantin,
1. Can you provide us a link to your shop ?
2. Can you show me some screenshot of how did your filters configuration.
13 years 9 months ago #83490 by cosg2004
Hello Mohamed,
I do not have the site live yet (still on my Ubuntu linux server laptop for development).
But here you are the screens of the setup.
No results as you can see.
Time to create page: 0.334 seconds
