Are conditional products possible ?
- datapunter
12 years 10 months ago #138414
by datapunter
Are conditional products possible ? was created by datapunter
I would like to define product A
and also products A1 A2 A3
But products A1 A2 A3 should only be available for purchase on condition that the user/client has already purchased product A.
Product A will likely have been purchased some time in the past.
If not yet purchased then A1 A2 A3 can only be purchased together with A.
( having to buy A first and later A1 A2 A3 so in 2 steps would also be acceptable )
Is this possible with the standard version(s) ?
If not how difficult would it be to accomplish this with custom programming ?
12 years 10 months ago #138425
Replied by nicolas on topic Are conditional products possible ?
1. You can use the "user group after purchase" option of the Business edition for product A to add the user to a specific user group after a user purchases it. Then, you can restrict the products A1 A2 and A3 to only that user group so that they don't show if the user hasn't purchases A already.
2. If you add products A1 A2 A3 as an option of product A, the user will be able to add them to their purchase as options of product A.
So yes that's possible.
The following user(s) said Thank You: datapunter
- datapunter
12 years 10 months ago #138495
by datapunter
Replied by datapunter on topic Are conditional products possible ?
I've tried it on the demo site but doesn't quite work.
If you purchase product A you become a member of GroupA.
Products A1 A2 A3 depend on membership of GroupA
If A1 A2 A3 are options to A then they do not show as options,
since A has not yet been purchased this makes sense as you are not yet a member of the GroupA.
To get the options A1 A2 A3 you would have to buy A and then re-buy A with options.
Without the options, A1 A2 A3 as seperate products you get a 2 stage process,
first buy A and then you can buy A1 A2 A3 in a second purchase, acceptable for me.
Problem is i want people to see A1 A2 A3 right from the start, so they know those products exist, what the specifications are, what the price is and so on, just not be able to buy them. ( it would be pointless to buy A1 without having A as A1 is completely useless without A )
So i tried this:
Define products A A1 A2 A3 as available to all and A1 A2 A3 options of A.
Then i put A in category A and made the category available to all.
Then i put A1 A2 A3 in a sub-category and made that category dependend on membership of GroupA
Now i only get to see A with 3 options, so there i can do a group sale.
Once purchased i then get to see the sub-category with A1 A2 A3 and i can add a product without having to re-buy A.
Still not quite what i want but close.
Question:
How difficult would it be to add a condition to a sale ?
So define A A1 A2 A3 as products visible to all, allowing A1 A2 A3 to be options to A so a group sale is possible.
But generate a warning and refuse a sale for A1 A2 A3
unless the client already purchased A OR is purchasing A at the same time.
It would be great when a user is viewing A2 for example that the 'Add to cart' is not present with a message 'This product can only be purchsed .after product A has been purchased. (or together with product A)'
The same message would need to appear for users not yet logged in.
So i tried this:
Question:
12 years 10 months ago #138616
Then, instead of restricting the A1 A2 A3 products to a user group, you could restrict their price to the user group and turn off the "display add to cart for free products" option of the configuration so that users wouldn't be able to add the product to the cart if not in the group but would still be able to see it.
Now if you want to display the add to cart button all the time, and really add a condition to the sale process to dynamically check whether the current user has purchased A or has it in the cart, you can always do it by developing a HikaShop plugin and implementing a trigger such as onBeforeCartUpdate: www.hikashop.com/support/documentation/6...umentation.html#cart
- datapunter
12 years 10 months ago #138629
by datapunter
Thanks,
i'll look into the second option,
makes more sense and seems more robust to me.
