Problem adding Product+Option to Cart
9 years 9 months ago #262058 by rhinoboy82
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.6.28
I came across a problem that you might see if you can duplicate.
I have a product with an option. If I include the option (set it to "Yes") and then click Add to Cart, it works fine. If I then click Add to Cart a second time, without leaving or refreshing the page, the quantity for the main item is incremented, but the quantity for the option item is not.
I got around this because setting "Group options with product" to "Yes" in Configuration. When the items are grouped, adding to cart multiple times correctly increments the single, grouped cart item.
On a related note, the "Group options with product" also solved another issue for me: In my situation, the option item is "free" so I only want one to be available with purchase of the main item. However, if the items are not grouped, it is possible for someone to change the option item's quantity independent of the main item.
By the way, the "Group options with product" is really cool. I couldn't do what I need to do without it.
9 years 9 months ago #262062 by Jerome
Please indicate your HikaShop 3 build number.
www.hikashop.com/forum/hikashop-3-0-beta...ime-add-to-cart.html
9 years 9 months ago #262110 by rhinoboy82
HikaShop Business 3.0.0 [1702070929]
9 years 9 months ago - 9 years 9 months ago #262127 by Philip
Can you try to re-download the last build [1702130950] that may solve your issue.
If that don't work, please provide an Url link to your concerned product in order to better understand your issue, because on our side we can't reproduce your issue.
Note : You can use our Contact us form if needed to provide it, just think to use this topic subject in the message subject.
Awaiting news from you.
Last edit: 9 years 9 months ago by Philip.
9 years 9 months ago #262226 by rhinoboy82
The latest build did indeed solve the problem!
