connection between joomla-users and hikashop-users
12 years 8 months ago - 12 years 8 months ago #147621
by renew
connection between joomla-users and hikashop-users was created by renew
-- Joomla version -- : 3.1.5
Hi there,
i have got some general questions about the user-handling...
I just realized, that the new hikashop-users also get an own joomla-user.account.
1) The problem is, that the new hikashop-users cannot login, because the joomla-account is not activated automatically. Which settings are wrong?
2) Which joomla-user-group should the hikashop-users get? where can I set this?
3) And is it really necessary that hikashop-users get s an joomla-user-account on that site?
Where can i find general infos about hikashops user-handling?
THANK YOU!!!
Hi there,
THANK YOU!!!
Last edit: 12 years 8 months ago by renew.
- Thank you received: 1778
12 years 8 months ago #147629
by Mohamed Thelji
Replied by Mohamed Thelji on topic connection between joomla-users and hikashop-users
Note that Hikashop use Joomla users, that's why when you create an "Hikashop user" it also create a Joomla one.
1. You'll be able to control it through "Control panel->Global configuration->system->'New User Account Activation'"
2. You'll be able to control it by using for example the "User group after purchase" option through your product configuration page
3. Yes
3. Yes
The following user(s) said Thank You: renew
12 years 8 months ago #147710
by renew
Replied by renew on topic connection between joomla-users and hikashop-users
thank you!
do you mean at 1) joomla->users->options-> and here "allow user registration" ans "new User Account Activuation - "self"?
2) Sorry I don't find this setting... where is that? And what setting would you suggest? Now it new Users get the group "registered..
THANK YOU
THANK YOU
12 years 8 months ago #147736
by Xavier
Replied by Xavier on topic connection between joomla-users and hikashop-users
1. Yes in Joomla > users > options. You can set the activation to "none" to be directly registered or "self" to receive a confirmation link in an email.
2. The hikashop users can be only Joomla registered users as it's configured by default.
12 years 8 months ago #147738
by renew
Thanks a lot!!!
