Problem with edit of address in user control panel
10 years 9 months ago #229522 by gigi974
-- Joomla version -- : 3.4.8
We have the problem with editing of addresses in user control panel (front end). When you click on edit link the popup opens but it shows the index html of our page. Tried with mootols and bootstrap and result is the same.
Also formatting of the forms in popup is not in the css style of the page.
We use joomshaper organic life template.
What could be wrong? :unsure:
10 years 9 months ago #229567 by nicolas
Please try after changing the "popup mode" to "vex" in the HikaShop configuration.
10 years 9 months ago #229643 by gigi974
the same problem persists.
10 years 9 months ago #229681 by nicolas
The problem is that when the address edition URL is called, your website redirects it to the home page:
take.ms/wHmDr
I suppose that it's something linked to the SEF on your website.
10 years 9 months ago #229871 by gigi974
I will check, since the same behaviour is with vex and w/o... I saw you logged onto the site, which runs 2.6.0., we have 2.6.1. in test enviroment only for now.
Will come back later
10 years 9 months ago #230005 by gigi974
yes if I disable SEO it works. I've tried combinations of SEO, joomla seo, sh404sef, to see the differences, but with both it won't work.
Don't know why??
10 years 9 months ago #230093 by nicolas
It might be linked to a system plugin, or the htaccess file of your website.
So check the system plugins (you can try disabling them one by one), and check that the htaccess doesn't have strange rules that were added.
10 years 9 months ago #230129 by gigi974
I doubt it is htaccess as this was the first thing I've tested (with default one). I'll check for prugins...
10 years 9 months ago #230263 by gigi974
Hi, we tested various configurations and I'm 99% sure that is hika + default joomla sef case. Writing you to support email.
