Mailing problem
3 years 3 months ago - 3 years 3 months ago #353409 by mcklusky
Mailing problem was created by mcklusky
-- HikaShop version -- : 4.7.4
-- Joomla version -- : 4.3.3
When a customer wants to register at my shop it displays an error : translated to english it says : WARNING There was a problem with the emailsending process, no activationlink was send to the adress you provided, please contact the admin.
Anyone that can point me in the right direction that i have to look ?
Last edit: 3 years 3 months ago by mcklusky.
3 years 3 months ago #353418 by nicolas
Replied by nicolas on topic Mailing problem
It says there is a problem with the email sending. Could you use the test email button in the Joomla configuration in order to make sure that what you've configured there is working ?
Could you also check the email settings under the Main tab of the HikaShop configuration page with the recommendations of your hosting ?
The following user(s) said Thank You: mcklusky
3 years 3 months ago #353422 by mcklusky
Replied by mcklusky on topic Mailing problem
The test email works correct, i will check the hikashop configuration, the problem started after the last joomla update.
3 years 3 months ago - 3 years 3 months ago #353423 by mcklusky
i think i just found the problem, will test right away
EDIT: problem solved, after the last update some fields in the email tab under configuration were empty.
Thanks for the help !
