Hikashop affilate program problem
14 years 6 months ago - 14 years 6 months ago #44692
by KRStwo
Hikashop affilate program problem was created by KRStwo
I try to enable Hikashop affilate progran and create baner.
URL: domain.com/?friend_id=1 from user A
Then i register new user B from this url
Made a new order by User B change it status to shipped, and nothing happend with User A bonus it still 0
How can i track refferal user id in system while new partner is registering?
System plugin is enabled.
What's wrong?
What's wrong?
Last edit: 14 years 6 months ago by KRStwo.
14 years 6 months ago #44693
by KRStwo
Replied by KRStwo on topic Re: Hikashop affilate program problem
I found user_partner_id in hikashop_user table
and it 0 at all users.
What's wrong?
How can i track ths bug?
What's wrong?
14 years 6 months ago #44753
by KRStwo
few more tests
i try to manually change user_partner_id in hikashop user table, to referral's user id
user A has a id=1
user B has a id=88
i try to set at user B user_partner_id to 1. nothing changed
what i do wrong? how i shoud diagnose the problem?
support please help me
user A has a id=1
user B has a id=88
14 years 6 months ago #44886
Replied by nicolas on topic Re: Hikashop affilate program problem
The partner for orders do not use these fields for sales fees but the order_partner_xxx fields of the hikashop_order table.
If you go in the Affiliate->Clicks menu, do you see the click of your user B ?
If you look in the cookies of the browser of user B, do you see an affiliate cookie for your website ?
If yes, it means that the system detected the user B as being an affiliate of the other user. Otherwise, edit the user A via the HikaShop customers listing and make sure that the affiliate program is activated for him.
Time to create page: 0.172 seconds
