product description/custom field in cart view
14 years 1 month ago #59944 by Christoph59
how can I display the product description in the checkout cart view. Also, how can I display a product custom field (which I fill in when editing the product) in the checkout cart view and later on on the order / invoice.
Can you also help with that: how can I display the product variant/option chosen in the cart module view.
Many thanks!!
Christoph
14 years 1 month ago #60045 by nicolas
That's a lot of things :)
1. in the file 'cart' of the view 'checkout' via the menu Display->Views you can add the code:
<?php echo $row->product_description; ?>
after the code:
<?php echo $row->product_name; ?>
2. in the file 'cart' of the view 'checkout' via the menu Display->Views you can add the code:
<?php echo $row->CUSTOM_FIELD_COLUMN; ?>
after the code:
where CUSTOM_FIELD_COLUMN has to be replaced with the column name of the field.
3. For the invoice, you can do that in the file "invoice" of the view "product" of your back end template via the menu Display->Views.
4. The product characteristic is displayed automatically on the cart unless the "Append characteristics value to product name" option of the configuration is turned off. So you should check on that.
14 years 1 month ago #60051 by Christoph59
great thanks, will check today
christoph
13 years 6 months ago #93210 by paddyrolls
Nicolas
Could i ask for more information
If I modify the file 'cart' of the view 'checkout' and add in my custom fields for type product, will the information be printed on the order and invoice as well.
thanks
Patrick
13 years 6 months ago #93420 by Mohamed Thelji
Hi Patrick,
If you modify the file 'cart' of the view 'checkout', just your checkout will be affected. if you want to edit your invoice, you'll have to edit the good file ;).
Hope this will help you a little.
Time to create page: 0.181 seconds
