How to display two kinds of price for a product?
14 years 2 hours ago #79173 by tinachou
Hi there,
I am confused about how to display two kinds of prices for the same product.
One is " Original Price", the other is "Member Only Price".
Where Can I set up such setting and display the two prices in the product page.
The final charging price is "Member Only Price", of course.
Thank you very much. :)
13 years 11 months ago #79201 by Mohamed Thelji
I think that you can :
- Set 2 price to your product through the tab price of your product page.
OR
- Create customfield and use it through your product view (this method would require some skill in PHP)
Hope this will help you.
13 years 11 months ago #79252 by joomleb
Why not use Seblod to do it?
13 years 11 months ago - 13 years 11 months ago #82527 by tinachou
Hi there,
I use the first method to add another price in the product info setting.
And it turns out two prices showing in parallel as the following pictures.
I hope to know:
(1) How to add some words above the two prices like:
original price
[strike]790 TWD[/strike]
Members-only price
700 TWD
But it raise another problem that how can I make the price has a strike sign?
(2) How to specify the "Members-only price" is the price being charged rather than the "orginal price"?
Thank you so much :) :) :)
Last edit: 13 years 11 months ago by tinachou.
13 years 11 months ago #82566 by Xavier
To add some text, you can edit the view "product / listing_price" in this view add the text before the concerned parts.
To make the price has a strike sign, you can add a class on the first displayed price and apply a css property on it to strike the text.
The lower price will be loaded by default. You can restrict this price to the "Members" group. By this way the other customer will have the default price and the members the lower one.
13 years 11 months ago #82626 by tinachou
Dear,
Thanks for the quick reply. Your support is very helpful.
I tried to look at the php file of product/listing_price. I guess I need some hints.
Can you tell me which part should I adjust in order to show two kinds of text above the two prices?
I am very afraid to mess up the code.
Thank you so much. :)
13 years 11 months ago #82721 by Xavier
After seeing the code, I think that you just have to add two translations in the language file, HikaShop > Configuration > Languages.
Try to add two entries like:
PRICE_BEGINNING_0 = "original price"
PRICE_BEGINNING_1 = "Members-only price"
