graphic problems with a responsive template
13 years 7 months ago #97836 by lacasetta
I'd like to change my template with a new responsive template one.
On my test site i noticed two issues.
First
The menù to chose the variants is vertical and so a little bit confused.
You can see it here:
www.gmonamour.netsons.org/en/negozio-onl...o/6-ceci-bio-vendita
In my actual template i have it orizontal and it is better.
How can i set it orizontal?
Second
Some Hikashop icones are quite double.
You can see them in my screenshot attached
How can i fix that?
my site with Hikashop
www.lacasettabio.it
13 years 7 months ago #97838 by lacasetta
13 years 7 months ago #97880 by Xavier
The variants problem is a template issue. You have to remove the css property "display: block;" on the "label" in the file " www.gmonamour.netsons.org/templates/kaiser/css/formelements.css "
For the doubled images it's probably because there is a repeat applied on the images. Try to set the repeat to repeat: no-repeat; in css.
13 years 7 months ago #97907 by lacasetta
For the variants you're right; now the problem is solved! Thanks!
For the double images could you tell me what kind of the css file i have to work?
www.lacasettabio.it
13 years 7 months ago #98138 by Xavier
You have to edit the frontend css file in "Config > Display > CSS" and edit the class: .icon-32-add_cart to add the property: background-repeat: no-repeat;
13 years 7 months ago #98212 by lacasetta
perfect!
Solved!
Thanks a lot!
www.lacasettabio.it
13 years 7 months ago #100884 by lacasetta
I'm sorry but i had to chage my template again!
Now i have the same problem tha you can see here: www.lacasettabio.it/en/negozio-online/pr...c-chickpeas-for-sale
Also on ceckout>adress i have the icon "change" out of its place. You can see it in my screenshot.
Could you help me again, please?
www.lacasettabio.it
13 years 7 months ago #100886 by lacasetta
13 years 7 months ago #100897 by Jerome
It's a known issue which come from the template.
Some templates have a bad handling of joomla 3 bootstrap rules.
www.hikashop.com/en/forum/4-how-to/80674...floating.html#100190
www.hikashop.com/en/forum/4-how-to/77125...-hover-js.html#84203
www.hikashop.com/en/forum/4-how-to/80474...-checkout.html#99408
Best regards,
13 years 7 months ago - 13 years 7 months ago #100944 by lacasetta
OK, I'm going to see the "change" button issue.
How about for:
the menù to chose the variants is vertical and so a little bit confused.
Could you help me, please?
www.lacasettabio.it
Last edit: 13 years 7 months ago by lacasetta.
13 years 7 months ago #100946 by lacasetta
i tried to fix with Nicolas said:
Nevertheless, if you want to remove the class="modal" on a tags, you can change the code:
$this->getAttr($attr,'modal')
$this->getAttr($attr,'')
in the file administrator/components/com_hikashop/helpers/popup.php
But it doesn't work.
www.lacasettabio.it
13 years 7 months ago #100958 by Mohamed Thelji
you should then try the second solution which is :
The proper solution would be to not use .modal but div.modal in the their extension's modal.less file.
13 years 7 months ago #101032 by lacasetta
Would you be so kind to give me more detailed instructions, please
www.lacasettabio.it
13 years 7 months ago #101106 by Xavier
You have to edit the tempalte css file in order to replace the .modal class properties to div.modal.
By this way it will not display the edit buttons in popup.
13 years 7 months ago - 13 years 7 months ago #101167 by lacasetta
I'm sorry but i can not find the .modal class on my template.css file.
Could you give me more information about it, please?
How about for:
www.lacasettabio.it
13 years 6 months ago - 13 years 6 months ago #101332 by Jerome
Taken from your website:
www.lacasettabio.it/templates/kallyas/cs...es-..%2Fcss%2Fcustom
In this CSS file:
.modal{position:fixed;top:10%;left:50%;z-index:1050;width:560px;margin-left:-280px;background-color:#ffffff;border:1px solid #999;border:1px solid rgba(0,0,0,0.3);*border:1px solid #999;-webkit-border-radius:6px;-moz-border-radius:6px;border-radius:6px;outline:none;-webkit-box-shadow:0 3px 7px rgba(0,0,0,0.3);-moz-box-shadow:0 3px 7px rgba(0,0,0,0.3);box-shadow:0 3px 7px rgba(0,0,0,0.3);-webkit-background-clip:padding-box;-moz-background-clip:padding-box;background-clip:padding-box}
Last edit: 13 years 6 months ago by Jerome.
13 years 6 months ago #101375 by lacasetta
I'm so sorry.
But i'm not be able to find it.
You mean in the file:
template>kallyas>css>template.css
Is it correct?
www.lacasettabio.it
13 years 6 months ago #101411 by Mohamed Thelji
Yes, I think that he was talking about this file :).
13 years 6 months ago - 13 years 6 months ago #101587 by lacasetta
I'm going crazy.
But I have found it. It was in the file "bootstrap.css" !!!
I do not know why you had another file, but it does not matter.
It is solved.
For the issue
I solved by myself it was the css property "display: block; Always on "bootstrap.css" file.
www.lacasettabio.it
Last edit: 13 years 6 months ago by lacasetta.
13 years 6 months ago - 13 years 6 months ago #101590 by lacasetta
I'm very sorry but i noticed a new problem on the user control pannel.
There is something strange and wrong as you can see on my screenshot.
I have the same problem with my test site where i didn't change the template modal class.
Could you help me please?
www.lacasettabio.it
Time to create page: 0.131 seconds
