Add parts to cart if not on stock
- info@ifparts.com
13 years 2 months ago #120833
by info@ifparts.com
Add parts to cart if not on stock was created by info@ifparts.com
I want to have the possibilty to ad products to the shopping cart when they are not on stock. (So my clients can order parts not available)
I am unable to change this setting, are you able to help me with this?
- Thank you received: 1778
13 years 2 months ago #120843
by Mohamed Thelji
Replied by Mohamed Thelji on topic Add parts to cart if not on stock
I don't think that this can be possible without some Hikashop code customization, but you can use the "waitlist" feature, then your customer will be able to ask you for an automatic notification when the product will be available.
You can enable the "waitlist" through "Hikashop->System->Configuration->'Features'->'Waitlist'".
Hope this will help you a little.
- info@ifparts.com
13 years 2 months ago #120853
by info@ifparts.com
Replied by info@ifparts.com on topic Add parts to cart if not on stock
Hello Mohamed,
Thank you for your solution.
Is it correct that the waitlist is only for the commercial version? Or did you mean the wishlist?
Greetings Kaz
Greetings Kaz
13 years 2 months ago - 13 years 2 months ago #120886
by Eliot
Replied by Eliot on topic Add parts to cart if not on stock
Waitlist and wishlist are both available for all Hikashop version
EDIT: thery are actually both available commercial version, my bad.
Last edit: 13 years 2 months ago by Eliot.
- info@ifparts.com
13 years 2 months ago #121017
by info@ifparts.com
No problem!
So there is no other way than purchasing it...?
Fo all your help I think I must! And will.
13 years 2 months ago #121023
by Eliot
Indeed, purchasing is probably the best solution
Take a look at the compare page to see what you really need
www.hikashop.com/extensions/compare-versions.html
- info@ifparts.com
13 years 4 weeks ago #130035
by info@ifparts.com
Hello Eliot,
I have purchased the commercial version a few weeks ago.
But the Waitlist solution is also not helping me in this moment.
I am able to deliver many parts, but i only have 500 different parts on stock (From a total of 35.000)
I have 2 questions.
1. What does it cost to customize my shop, so clients can order parts that are not on stock?
2. Can i change the notification settings so I get a notification when a part is added to a waitlist.
Greetings Kaz
I have 2 questions.
Greetings Kaz
13 years 3 weeks ago #130471
by Xavier
Replied by Xavier on topic Add parts to cart if not on stock
Purchasing out of stock products is on out TODO list. It's not yet available.
If you need this feature soon, you can ask for a quote via our contact form.
You can too post your resquest in the commercial jobs section of this forum.
To follow the waitlists, in a recent version of HikaShop we added the menu Customers > Waitlist which allow you to manage all the waitlists.
- info@ifparts.com
13 years 3 weeks ago #130485
by info@ifparts.com
Hello Xavier,
Thank you for your message.
I will wait for the update, is it possible to notify me when this option is available?
Is it possible to not show the quantity on stock?
- info@ifparts.com
13 years 3 weeks ago #130493
by info@ifparts.com
Hello Xavier,
I have just solved my problem.
I erased some text in the language option.
Now I can ad stock, without showing it to the customer.
So they can order parts, I not really have on stock.
13 years 3 weeks ago #130552
Replied by nicolas on topic Add parts to cart if not on stock
If you want to be notified of new releases, the best is to subscribe to our twitter feed:
twitter.com/hikashop
The following user(s) said Thank You: info@ifparts.com
