T & C Link does not work!
12 years 8 months ago #146772 by GoMami
Hello community, I use the HikaShop Starter 2.3.0
Sorry link does not work for the T & C. (Yes, I have read the terms and I accept them.)
Can someone there to help you?
Thank you.
12 years 8 months ago #146781 by Mohamed Thelji
HI,
Can you tell me :
- What do you exactly mean by the "T&C link doesn't work" ? Can you give me more details ?
- If you are having a JavaScript error through your checkout workflow or when you click on the T&C link ?
12 years 8 months ago #146782 by GoMami
Replied by GoMami on topic T & C Link does not work!
Thanks for the reply.
There is a link (see image in the attachment) and if I click on it nothing happens...
Here is the live link: lashem.ch/lash-care/checkout.html
12 years 8 months ago #146817 by Mohamed Thelji
I just tested it through your website and noticed some JavaScript errors, so the solution will probably be to correct these JavaScript errors, note that using the jQuery Easy will probably help you.
12 years 8 months ago #146834 by GoMami
Thanks a lot Mohamed for your support! we will try it out! BR Patrick
