(SOLVED) Some problems when add order in backend
12 years 8 months ago - 12 years 7 months ago #147580
by vaughan
(SOLVED) Some problems when add order in backend was created by vaughan
wpb.es
-- HikaShop version -- : 2.2.3 bussiness
-- Joomla version -- : 3.2.1
-- PHP version -- :5.4
I have 2 problems.
1- When I add a new order in backend, don´t increases 1 unit in table hikashop_product in field product_sales
2- When I add a new order in backend, reduce 2 units in stock, but I add select 1 unit
I need add orders in backend, because some clinets phone me to buy directly, and I need know how many sales I have in all products
I use variants in each product
I have 2 problems.
Last edit: 12 years 7 months ago by vaughan. Reason: Solved
12 years 8 months ago #147609
by Xavier
Replied by Xavier on topic Some problems when add order in backend
I tried to reproduce the problem on my end, but the stock is increased correctly, like the product sales.
Could you give us more informations about the installed extensions, modules or plugins you have.
It's probably one of them which is causing the issue.
The following user(s) said Thank You: vaughan
12 years 8 months ago #148354
by vaughan
Replied by vaughan on topic Some problems when add order in backend
I find part of my error, there was an error in my database structure in order_product table, there was not autoincrement in order_id field.
Now deduct 1 unit in each order, but the sales not increment in 1 unit (maybe a similar error) I'm comparing a new installation tables wint my production site, but ican't find my error....
12 years 8 months ago #148357
by Jerome
Replied by Jerome on topic Some problems when add order in backend
If you do not have the official tables in your database. It will be difficult to reproduce your problem.
It asked for a deep analyze in order to understand why the stock is not modified and look at the request which generally increase the product sale counter.
12 years 7 months ago - 12 years 7 months ago #151042
by vaughan
Well I solved my probelms with tables, but I still having some problem when I add an order in backend, don´t add 1 unit in product sales but only happen this error if the product has variants (characteristics) I check in the yellow box to add a product and select variants in select list and then I select the variant I want to add into the order, It's correct?. If I make a order in frontend like a customer, works fine and add 1 unit in product_sales, in backend NO.
I see o
I installed a local test site, a new installation, and I have same problem, don´t add 1 unit in product_sales field in the table hikashop_product when I create a new order in a product with variants in backend.
Why it happens?
Thanks for all
I see o
Why it happens?
Thanks for all
12 years 7 months ago #151773
by Jerome
Please edit the file "administrator/components/com_hikashop/classes/order_product.php" and replace the line
By:
It should fix your problem.
$query = 'UPDATE '.hikashop_table('product').' SET product_sales = product_sales + '.$k.' WHERE product_sales >= '.(-$k).' AND '.implode(' AND ',$filters);
$query = 'UPDATE '.hikashop_table('product').' SET product_sales = product_sales + '.$k.' WHERE product_sales >= '.(-$k).' AND ('.implode(' OR ',$filters).')';
12 years 7 months ago #151838
by vaughan
Great! Great! Great! Great! Great! Great! Great! Great! Great! Great! :woohoo: :woohoo: :woohoo:
Thanks a lot!!!! works fine!!!
Best regards!
Best regards!
