Admin order confirms not received
12 years 3 months ago #166931
by optimized
Admin order confirms not received was created by optimized
starsupplyalliance.com/
-- Joomla version -- : 3.2
-- PHP version -- : 5.4
-- Error-message(debug-mod must be tuned on) -- : Admin order confirms not received
While 'Ask a question on the product' emails are geing received the admin emails confirming the emails are not being received.
A screen shot on the System config page is attached
What could be the issue?
Thanks,
Mike
Thanks,
Mike
12 years 3 months ago #166934
Replied by nicolas on topic Admin order confirms not received
It's probably a problem with the email server on your server which refuses it.
It can be because of the bounce address, or maybe the "add names", or the "charset", or the "multipart" on that configuration page.
If you ask your hosting company, they should be able to tell you. Otherwise, you can test the different options and see if changing each one one by one helps for that.
