2 For 1 on set products from a category.
12 years 1 week ago #179342 by boxchilli
I'm trying to find a way which if you purchase 2 products from category X you get an additional product from category X for free (with the cheapest being free)
What's the best way forward with this?
12 years 1 week ago #179367 by nicolas
You can develop a Joomla plugin of the group hikashop implementing the trigger onBeforeCartUpdate( &$cartClass, &$cart, &$product_id, &$quantity, &$add, &$type,&$resetCartWhenUpdate,&$force,&$do) so that each time something is added/removed to cart, you can check if there are enough products from that category to add/keep/remove the free product in the cart.
You can also implement the onBeforeCalculateProductPriceForQuantity trigger to set the price of that product to 0 before the calculations for the total of the cart.
12 years 1 week ago #179410 by boxchilli
Thanks for this Nicolas.
Is there no way to do this out of the box? Or to do this as 2 for 1 on the whole store?
12 years 6 days ago #179430 by Mohamed Thelji
A solution can be to use that Joomla extension .
