Invoice numbering system
11 years 10 months ago #187968 by Tormentor667
-- url of the page with the problem -- : schmuckiversum.de
-- Joomla version -- : 3.3.6
Dear Hikashop Team,
I am using Hikashop Essential for a client and at the moment he is running into problems concerning the numbering of the invoices. Hikashop seems to generate them randomly (we have J8, H3, G6 and similar numbers) and not continuos (like 001, 002, 003 and so on).
In Germany the finance office seems to be a but stubborn when it comes to invoice numbers, so is there way to make the invoice numbers continous?
Thanks alot,
best regards,
11 years 10 months ago #187973 by Jerome
Replied by Jerome on topic Invoice numbering system
The order number or the invoice number are not random at all ; they are base on the "order id" and "invoice id" which are sequential numbers.
Please see our documentation for the order (and invoice) number format
www.hikashop.com/support/support/documen...nfig.html#main_order
The following user(s) said Thank You: Tormentor667
11 years 10 months ago #188297 by Tormentor667
Thanks, everything is so much easier when you know where to look :)
11 years 7 months ago #199664 by saardvark
Replied by saardvark on topic Invoice numbering system
This post is very helpful, however I need to start the sequential numbering at 4000. Is there a way to do that?
so it would be 4000, 4001, 4002, etc and would need to roll over to 4999, 5000
Can this be done?
thx
11 years 7 months ago #199706 by nicolas
Replied by nicolas on topic Invoice numbering system
If you're talking about the order id ( for the tag {order_id} ), you can just change the auto_increment value of the hikashop_order table to 3999 and next order will have its order id at 4000:
www.hikashop.com/forum/4-how-to/7820-spe...at.html?lang=en#7825
If you're talking about the invoice id ( for the tag {order_invoice_id} ), you can create a first dummy order and change its order_invoice_id in the hikahop_order table to 3999 via phpmyadmin and next confirmed order will have its invoice at 4000.
