System configuration for "Order"
11 years 8 months ago #194144 by lousyfool
-- url of the page with the problem -- : local
-- Joomla version -- : 3.4.0
In the system configuration, under -> Main -> Order, I'm finding these fields, one brand new in 2.4.0, and the other unnoticed since 2.3.5, I guess. Nothing in the documentation or elsewhere, so I dare asking what exactly they mean and affect:
1. Unpaid order statuses
2. Payment capture order status
While the first might be self-explanatory (any order statuses before "Payment confirmed order status"?), I can't imagine what the second means. And for both I wonder what my entries may cause... or worse, what wrong or no entries will cause! ;)
Thanks for the briefest enlightenment!
11 years 8 months ago #194148 by Jerome
These options are there since several versions ; I added them for the authorize/capture system I made for HikaDeal.
For the moment only the "ogone" payment plugin support the authorize/capture mode but I will introduce it in Paypal (and some other payment plugins) in the future (to be able to release HikaDeal correctly).
But the idea is that you can let the customer pay, the money will be authorize but not captured.
When the order will change his status (regarding the second option), the payment will perform the capture of the money.
The following user(s) said Thank You: lousyfool
11 years 8 months ago #194211 by lousyfool
Ah, that's what they're for. Thanks Jerome.
So, I'll leave them empty as I'm not using "Ogone".
I'm looking at a 2.3.5 test install now, and (1.) is definitely not there, while (2.) is.
Anyway, maybe I've been the only one noticing so far, but I suggest to put at least a brief hint ("For future use" or so) into the documentation - would sure help those who are stumbling over it - like me.
6 years 8 months ago - 6 years 8 months ago #316218 by joomleb
Hi guys,
PHP 7.3.15 + Joomla 3.9.15 + HikaShop business 4.2.3...
Jerome wrote: ...These options are there since several versions ; I added them for the authorize/capture system I made for HikaDeal.
1 - I'm not able to find documentation about and I noted the tooltip still say N/A. Anyway, Please, What are the up to date payment plugins that support the authorize/capture mode ?
2 - In your experience, Can the "Capture" order status be useful for the manual payments like "Bank transfer" ? If yes, in which cases ?
3 - When I click on "order" that should reorder the Order statuses, the "save order" and all icons are lost and I'm not able to reorder anymore the Order statuses. I had to logout and login to restore the feature. Please, What am I missing ? - here an image
4 - Why not reorder the columns following a chronological more logic order ? Is there a way to do it ? An example from my point of view:
Created - Unpaid - Cancellable - Cancelled - Capture - Confirmed - Invoice - Print invoice - Download - Serials - Affiliate - Statistics
Last edit: 6 years 8 months ago by joomleb.
6 years 8 months ago #316234 by nicolas
1. Ogone is still the only one.
2. No, that won't help. the capture/authorize mechanism is only for credit card transactions.
3. Thank you for your feedback. That's a bug no one reported yet. We were able to reproduce it and we'll add a patch for the next release.
Note that the icons being "lost" is because the ordering is not allowed. It should actually only allow the ordering changes when the listing is sorted on the order column. So the behavior should be opposite, and the default ordering should be on that column.
4. Thank you for your feedback. That's a good point. We'll look at changing that for the next release.
The following user(s) said Thank You: joomleb
6 years 8 months ago #316254 by joomleb
1 - 2 - Thanks !
3 - 4 - Thanks, I'll stay tuned !
