Display in Frontend counter for nb products sold ?
- codewarrior
11 years 7 months ago #196783
by codewarrior
Display in Frontend counter for nb products sold ? was created by codewarrior
-- HikaShop version -- : 2.2
I would like to display in the frontend a counter with total nb products sold.
ie. there's an offer and I would like to display how much are sold on the period.
How could it be possible in a module ?
Thanks for ideas.
Thanks for ideas.
- Thank you received: 1778
11 years 7 months ago #196789
by Mohamed Thelji
Replied by Mohamed Thelji on topic Display in Frontend counter for nb products sold ?
Their is no option to do that, so you'll have to use some custom code which will require development skills.
- codewarrior
11 years 7 months ago #196977
by codewarrior
Replied by codewarrior on topic Display in Frontend counter for nb products sold ?
OK no problem.
Could you put me on the way to develop it ?
11 years 7 months ago #196983
Replied by nicolas on topic Display in Frontend counter for nb products sold ?
You can use such module in order to add your PHP code inside a module on your Joomla website:
extensions.joomla.org/extension/blank-module
In it, do first a query on the hikashop_order table in order to get the order_id of all the orders confirmed in that period and then do a second query to sum the order_product_quantity field of the hikashop_order_product table with the order_id in the list of the order_ids you got from the first query and you'll get your total number that you can just echo.
The following user(s) said Thank You: codewarrior
