get hikashop order info in custom component
11 years 3 months ago #211105
by kaya
get hikashop order info in custom component was created by kaya
-- HikaShop version -- : 2.x.x
-- Joomla version -- : 3
Hi dear
I need get hikashop order class methods and order info by order id in custom component.
How can get it?
thank you
Hi dear
How can get it?
thank you
11 years 3 months ago #211107
by Jerome
Replied by Jerome on topic get hikashop order info in custom component
You need to include the HikaShop helper.
Then you will have access to HikaShop function and cat retrieve the HikaShop order class.
if(!defined('DS'))
define('DS', DIRECTORY_SEPARATOR);
include_once(rtrim(JPATH_ADMINISTRATOR,DS).DS.'components'.DS.'com_hikashop'.DS.'helpers'.DS.'helper.php');
$orderClass = hikashop_get('class.order');
The following user(s) said Thank You: kaya
