- Thank you received: 5
Order id and order details issue
- rcanetwork
11 years 3 months ago #211615
by rcanetwork
Order id and order details issue was created by rcanetwork
-- Joomla version -- : 3.4.3
-- Error-message(debug-mod must be tuned on) -- : Frontend: none
Backend: order not found
Everything working fine, then I just try to edit last order id on database table "hikashop_order" via phpmyadmin like "3435435764" to test the order id and invoice id.
After then it's generating strange order no like, A3A5A0A2A1A4A7A6A0A9AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABARCTWWF
and order details also not showing if I click this order no.
Here attached current order configuration screenshot, unfortunately it's still in localhost.
11 years 3 months ago #211621
by lousyfool
Replied by lousyfool on topic Order id and order details issue
Why would you edit an order ID - or anything else - in the database? Doing so directly in the database is - like changing other key values in the database directly - highly destructive. Since various database tables, fields and their values are related to each other, your change has destroyed the relationships for at least this order.
It should go without saying that manual interference with the database is highly risky, and indeed, in your case harmful.
Change the order number back, if you can, or restore a backup.
11 years 3 months ago #211617
by Jerome
Replied by Jerome on topic Order id and order details issue
And what exactly did you do with the order_id or the invoice_id ?
Because the conversion of the order_id "3435435764" using the hikashop_base function is : "B3A4E3T5J4W3M5J764"
The following user(s) said Thank You: rcanetwork, sivaranjani
- rcanetwork
11 years 3 months ago #211655
by rcanetwork
Replied by rcanetwork on topic Order id and order details issue
I fixed it, thanks for reply.
